iSimple PXAMG issue with .37e
I think I messed something up.
I have a 2004 Acura TL without Nav.
After upgrading the PXAMG unit to the 37e release/revision, I inadvertently plugged in the unit with the dipswitches on.
The unit didn't work, so I unplugged it, and waited 15 minutes.
Then, I did not reconnect the unit, but turned on the radio, and no XM.
Changing the radio mode completely bypasses the 2 XM channels/modes.( XM1 & XM2)
So i re-plugged the PXAMG unit and still no XM.
Now I am without XM as well as the ability to listen to my iPhone music. I have the 3G iPhone with version 3.0.1.
Prior to upgrading the PXAMG to 37e, I had no problms using this unit.
Any ideas on how to get my XM back and then the PXAMG unit working?
NBP is a pain...
i'm assuming you switched the dipswitches back to off?
Press FM/AM a few times and then hit XM and very quickly rotate the tune knob till you see IPOD or AUX1/AUX2 and it should work.
If anything, you can disconnect your car battery for 30 minutes or so and reconnect it.
Yes, I did switch the dipswitches back to off.
I tried what you suggested, and it looks good/works now.
With this help, and help from AAMP tech support, it's back/working as normal now.
thanks. much appreciated.
Vejey Gandier
09-12-2015 08:59 PM
