iSimple
I installed the isimple ISHD651 into my 2004 TL just about a year ago. I have no complaints. If you are looking to stream your music wirelessly then it will do what you want and more.
Installation is straight forward because it uses a T-Harness at behind the radio for the factory integration connection. Your goning to spend the majority of your time removing trim panels and running the cables. The cables include a USB socket that is a input for smart phones and storage devices, the BT Mic if you choose to use it (pointless for our application) and a reset switch for when the unit needs reset.
If you search there is another member on here that documented his install and posted the pictures. I also have pictures from when I did my install. I can always upload mine if needed.
Arnold503 (10-03-2014)
Thanks I'm looking to do it within the next couple of months or sooner. I'm just not sure if install would be complicated, do I need to remove my navi or is it fairly accessable by removing some panels?
Vejey Gandier
09-12-2015 08:59 PM
Jskman987
08-30-2015 05:11 PM
