iPhone mount and charge?
I know I have seen some threads on this, but of course now that I have received my awesome Iphone 4s Xmas present I cannot seem to find the threads that I remember. And the clunky search is not helping.
I believe the one that I remember that seemed to be the best integration used a pro-clip mount mounted to the center console? I am in no means tied to the pro-clip option.
Any options would be appreciated as the battery life on this device is not to great when used frequently. Using it so stream music would be a nice option as well. Thanks in advance
g2teg (01-01-2012)
I use a Pro-Clip components with a cable run to the center console for power and audio and use a 1 amp USB adapter.
Apple iPhone 4 / 4S used with a Case - Adjustable Holder with Tilt Swivel and Pass-Through Connector -place iPhone in holder and it's connected
Horizontal support. -the higher mount helps me keep focus traffic
I never have to worry about power. I'm usually on con calls and streaming the video on the way to the office and arrive fully charged and get charge time on the way home.
Thanks Oracle! what cable are you using and how is it connected? Do you know the specific pro clip part numbers? pics of setup?
Acura TL 2004-2008 - ProClip Center Mount -Item No. 853464
Apple iPhone 4 / 4S used with a Case - Adjustable Holder with Tilt Swivel and Pass-Through Connector -Item No. 516165
I used a doc connector extender extension cable and an audio and sync cable.
Cant get a pic now.
2 amp USB adapters are available now. Not sure that it would help charge any quicker.
Cant get a pic now.
^ no aux input in my 06
