I-160: USA Spec Install
#41
Originally Posted by Walshstl
Ok so for the 05 TL there isnt a notch in the tray, did you guys just cut your own notch?
#42
Originally Posted by DMoyes
Yes, the USA Spec charges the iPhone perfectly.
What happens now, when I plug in the phone, I get a message that "this accessory wasn't made for the iPhone, and won't charge it", or words to that effect. The audio still works perfectly.
I've emailed USA Spec tech support (just now) and I'm hopeful they'll have a solution.
I'll keep you guys posted.
#43
Just to let everyone know, I upgraded to a 3G iPhone, and the USA Spec Hon2y doesn't charge it. The statement above related to the 1st-gen iPhone.
Keep us posted, however. My guess is that there are several companies in addition to USA Spec scrambling to find solutions right now.
#44
My guess is they need time to manufacture / ship them from China.
Contact info@usaspec.com and they will send you contact info including a phone number to obtain the new cable. I won't post the number here, as that would be rude.
Looks like I'm taking my dash apart again!
#45
Just got word from USA Spec... they say Apple changed the dock connector, they have a new cable in the works, and it will be ready in 6-7 weeks.
By the way, for anyone interested - this DOES NOT affect the iPod Touch. I upgraded my software to the new "iPhone 2.0" software the other day and the USA Spec module continues to charge the iPod Touch just fine.
#46
Full A-Spec 08 CBP TL-S
Originally Posted by blkaspec
i just installed mine today and i am SOOOOO happy!. finally, no more tape hiss. plus, i got my TomTom hooked up to it so i can listen to the movies through the car speakers. i havent really tested it out much yet, but from my initial playing around i am really happy.
#48
Regarding GMS Buzzing. If you want to not hear that buzz you should try this product I found at www.stopthebuzzin.com You can slip it under your phone and like magic it stops any buzzing. There is a video on the site that shows it.
#49
Regarding GSM Buzzing. If you do not want to hear that buzz you should try this product I found at www.stopthebuzzin.com You can slip it under your phone and like magic it stops any buzzing. There is a video on the site that shows it working in a chevy sub with cassette adapter.
#51
ahh that skipping is driving me wack! If it skips and is quiet inbetween the skip thats one thing, but it makes this static/buzz noise. Its really embarrassing and extremely annoying! Somtimes it skips quietly, but once or twice a day it makes this noise. Are you guys getting this? Im am pretty sure my cable is tight in the head unit. I might have to take everything apart again to make sure
As for the notch, when I want my ipod out I just pull the wire to the side and close the cover on top the wire. Definitely not as nice as having the notch but whatever it works. Kind of stresses the wire but dont think it hurts it any.
#52
#53
2006 TL
Storing the Touch (notice the notch Acura left us for the cord when its on the drink holder cover):
Great write up, thanks to you, i can now use my iPod in my car!
Forgive me if this has been said/asked... I have a 06, but i don't have that notch on my center console! Am i alone?
#54
#56
USASpec and video..
i heard the new connectors were out for the use spec and the iphone 3g, just dropped a note to usaspec today to see if i can pick one up, was using the headphone jack on my video ipod through doms unit.. obviously this won't work with the iphone since everything goes through the bottom connector
looking at different solutions running the power and video out of the bottom... i want to keep the functionality of the ipod navigation through the dash and wheel, but i want to have the option to play the video through the nav...
so while i could go with this cable..
and run the audio to the aux audio in on the usa spec then run the RCA video cable to Doms box... again this isn't something i want to do.. i loose charging, i lose control from the wheel and dash...
Another solution would be this cable...
I could run the USB to the center console or wire in another powerpoint/cig lighter under the dash.. and run the usb power to it.. but what a hassle.
which leaves to me an older A/V dock and cable extender...
the cable extender is here:
http://www.cablejive.com/extendercable.html
and the dock is from apple:
however not sure about audio running through the apple connector from the doc the usa spec.. i guess i could pick one up and test since its only $12 off ebay.. but what a hassle versus the headphone jack video solution!
If anyone has any ideas.. lets hear em...
#59
I suppose you have a point. Given that I live where we get less than 10 inches of rain per year, it really wasn't a concern for me.
#60
#64
So for some reason I cant seem to get access to the pdf document (installation instructions) posted at the beginning of the thread. Anyone have a copy they could send to me or repost?
is there any way you can repost the pdf document? I cant find another set of instructions for gaining access to the back of the radio and the link wont open :-(
#65
bball4t@gmail.com... thanks a bunch
#67
#69
http://enfigcarstereo.com/shopsite_s...A11_HON2Y.html
I use Simplify Media with my iPhone 3G in my TL with the USA Spec all the time. Check it out:
www.simplifymedia.com
Basically, I can listen to my home music library (90 gigs) from anywhere with my iPhone. I just need to leave my computer on.
#70
#71
Sent. Regarding the hosting, I don't think it can be done directly through the Board, but I may need to look into setting something else up.
#75
#77
would someone be able to send me the pdf as well? (i'm sorry i'm sure this is getting annoying)
mike.mattera@gmail.com
#79
#80
Sent to Mike and SpicyDorito.
Also, I received a PM from Ron A and he is working on a hosting solution. Many thanks to Ron A.
