I-058: playa4real's Peripheral PXAMG Install for a 3G Type S
#203
Good thing that we did reverse engineer it; I have had ipod tunes for the last five months (8,000 miles)!!! Beats waiting in line.
#204
How do I know if I have Nav Traffic capability? I have a 2007 TL (not type-s) w/nav and XM.
I subscribe to XM , I have never looked into Traffic as it is not available here in Canada. I just bought a PXAMG/PGHHD2 and can't get it to work, did I get the wrong harness?
#205
#206
#207
yeah i know its a bunch of silly questions, but need to make sure all of this has been done.
your car does have NAVTraffic (if its available in Canada)
#208
Thanks for trying to help, I think I've done everything right, maybe one of the "silly" questions will trigger a "doh!" moment for me ! Then they're not so silly after all.
I have tried the switch in the correct 2 down position, and all up when that didnt work. Everything connected as described (and rechecked numerous times) Latest firmware 36e in PXAMG and iPod, no matter what mode I get no sound.
The only thing that might be an issue is through this whole process I locked up my nav , it wanted my PIN code and I didn't have it at the time, so I could only go by the display up by the clock. Methinks I should still have had sound. Anyway my dealer gave me the code so the nav is up and working again.
yes it should be wired in the trunk. did you connect everything as described on page 1? dipswitch 2 in the right position? do you have the latest firmware? is the headunit switched to "IPOD"? if not try that, if that doesnt work, try switching the headunit to "AUX" you should hear the ipod playing, but will not see the text.
#209
Former Sponsor
I have had people plug the iPod cable into the wrong port on the PXAMG and there is no sound. The iPod cable needs to be plugged into the outside 8 pin port and not the inner port. The inner port is AUX2 as the outer port is IPOD and AUX1.
#210
I just went out to the garage and checked my cables - I have a PGHHD1 (my bad memory was telling me PGHHD2 - too much reading here I guess ). Everything plugs in fine. I redid it all (at the head unit, switch 2 up, 8 pin in the outside port) still no luck.
From what I think you're saying there is a physical difference in the plug- if I need PGHHD1 only that cable wil fit, not the PGHHD2 - am I correct? Maybe I should disconnect the battery but I'm afraid to do it as I don't have the radio code (bought the care 1 year old used).
This is extremely frustrating but I'm not giving up.
I don't think NavTraffic is available in Canada and would assume that the Canadian model TL would have the standard XM tuner. If that's the case then you'll need to install the PGHHD1 cable behind the radio. However, if you were able to plug the PGHHD2 harness in at the XM tuner then you do have setup for the PGHHD2.
#211
Former Sponsor
#213
#215
Haha, yes, everything is (as far as I can see) correct, and, although I would enjoy a cross-country drive , it's not really practical. Thanks for trying, maybe I'll give it one more shot tomorrow. There has to be one dumb thing I'm missing, unless one of the pieces is defective and if that's the case I have no way to find out.
#216
Fearless, I do not know how the radio is in a 2007 TL, but this sounds like how mine acted in my 2006 Accord. I had a quick reference card that did not show my radio layout. My radio did not have a tuning dial, it had a tune up and down button. I called Peripheral tech support and they told me to hit the XM button and then push the tune "up" button until Ipod showed on the screen. The PAC Audio site had a quick reference card for my stereo layout but the Isimple site did not. This may not be your problem but I thought I would try to help, good luck.
#217
Hi all, i bought the Isimple kit for the 2007 TL with nav/traffic; from Uncald4. i know this is simple plug and play application; but does any one know if Acura could void my warranty if i install this divice? i probably should have asked before i got it; but i still want it any ways.
#218
Former Sponsor
The Magnuson-Moss Warranty Act says that no dealer can void a warranty because an aftermarket product was installed. They can void the warranty if the dealership can prove that a fault on the vehicle was caused by the installation of the aftermarket product. From my experience a consumer level installation can be blamed very easily by the dealership.
#220
display issue?
I got my harness and unit last week and installed today. Travis you're the man for getting these out to us; playa4real your write up helped me every step of they way (literally had the laptop in the car with me).
I've got a question for all of you, does the song title and artist name remain displayed in the small upper screen? As of right now, the song title and artist name scrolls and then goes away and all I see is "XM-1 CH001" displayed. The same thing happens when I'm listening to XM. The song title used to stay displayed in the small upper screen but now it just says XM1-(which ever preset channel) CH 66. Its not a huge deal but I did like being able to see the song title displayed up there so that when I was looking at the nav screen I could still get song info.
So basically is this the way its supposed to be or is there something wrong?
#222
#223
I think I've asked this question before, but didn't really get what I'm looking for. From what I read, the peripheral unit is the best around for the TL with regards to playing music from an ipod or iphone with the most function (song display, steering wheel control, etc).. I think I'm ready to do the install, but I'd love to go ahead and install the back up camera and video from my iphone to the navi screen.
My question for those of you that have this set-up, do you have two different plugs/harnesses to plug into your iphone/ipod? It doesn't appear that the peripheral unit allows video to pass through. So, do you use the ipod plug from the peripheral unit for music, then something else, like the apple composite cable to Doms unit, to play video?
#226
Not in Canada, eh?
Below is copy of "form" I submitted to Peripheral Electronics. I have no confirmation that they received it so I am also submitting it here. Any help would be appreciated.
"I have a CANADIAN 2008 Acura TL-S. Bought PXAMG and PGHHD2 harness from GIG Harbor Autow Works (and was assured that this is what I needed for my car). Went to Future Shop to have it installed, and after 2.5 hours they could not get it to work. Installer called you [engineer at Peripehral Electronics] who said Canadian 2008 TL-S has older tuner and requires PGHHD1 harness, that needs to be connected to tuner, not sat box. I would like to confirm this with you before this turns into a $500 project.
Which harness? Where to connect? Dip switch settings?
(My PXAMG is serial number PX0409.36)
Will it still charge my iPhone?
Anything else I should know?
Do I send wrong cable back to Gig Harbor Auto Works for replacement? (Assuming that's the only issue?)"
Thanks for your help.
#227
Former Sponsor
Not in Canada, eh?
I like that the installer had a solution instead of just saying that it won't work.
For other Canadian TL owners.... Both the PGHHD1 and PGHHD2 kits have been installed in your cars. There is really no way to tell which tuner you have without pulling the carpet back and verifying the plugs on the XM tuner.
The older XM tuner will have a WHITE plug. The newer NavTraffic tuner will have BLACK plugs.
rgr : could you please shoot me a PM with your email address and shipping info? Thank you.
#229
just a heads up for all Canadian TL-S owners, mine also has the white plugs as mentioned above which means it needs the older cable. Guessing from this I think the majority of them have the older XM box
#230
Comprehensive Install Description
So, this looks like it is exactly what I am looking for but after reading all 6 pages of this thread I am unsure as to what I need exactly. If someone could please give me a list of parts, and where I can get them, that I will need to purchase (I have a 05 navi) and a description of how it needs to be installed, that would be great.
Thank you for all your help
#232
Former Sponsor
Click that link. For the 2005 TL w/NAVI you'll need the PXAMG and the PGHHD1. Nothing else. The kit comes with install instructions. Holler!
#233
So, I live about a half hour from you. Is there any way that I can just come and pick it up from you? That way you wouldn't have to worry about trying to ship it and I wouldn't have to pay for the shipping.
#235
Former Sponsor
!! TO EVERYONE !!
In the last month I sent out 3 replacement PXAMG's and 12 replacement harnesses. Whether it was a defective replacement or you ordered the wrong parts I expected the original part to be returned. I have received none of these parts back. WTF?
I'll be going though my invoices to find each person that has failed to return their part. If you're returning an exchange to me and it's on the way please let me know. I will not send you the nasty email reminder.
#236
I'm having trouble installing on my 06 TL w/Nav and XM. I have the PGHHD1 harness I tried installing it in the back. The ipod cord is connected to the right plug and I have dip switch 2 on and I disconnected the battery for 10 min. However when I turn on the ignition it goes straight into NAVI code input. Once I put the code in and press XM nothing shows up. I'm not sure what I'm doing wrong. When i put all dip switches up, the ipod shows up.. but there is no sound even when a song is playing. AND the xm does not work. Anybody know what I'm doing wrong? Do i have to install it into the HU?
#237
Former Sponsor
#239
