HVAC and Radio display gone dead - need help
Old 12-08-2018, 06:14 PM
aameetsha's Avatar
anyone here you can help - need help, in process of relocating my display of radio and climate contol, I had to cut all wires reaching from the car to the circuit board in the console. I cut all wires coming in below Center vent above dash to extend and in the process, shorted them - there was a spark and now everything is dead - blower starts by pressing Mode - something went wrong - any suggestions to check and fix. I am not sure which fuse controls power
Old 12-08-2018, 08:57 PM
Superunknown's Avatar
Why are you cutting and splicing with the battery connected
Old 12-09-2018, 02:30 AM
aameetsha's Avatar
Splicing
yes completely aware and totally missed trying to finish the task. I read through forum and seems Fuse 32 may need to be check which powers HvaC etc. another thing, I used 26 AWG for extending the wires and original wires are more like 18-20 AWG , not sure if circuit tripped due to higher amp. Do I have to replace with stranded 20 AWG
Old 12-10-2018, 06:46 AM
Bchester6's Avatar
Yikes. Check the fuse and replace if needed and wire sizes should be the same as factory and never downsized in any electronic application.
Old 12-19-2018, 03:35 PM
JMiles_T's Avatar
The safest route is to remove the buttons from the vehicle and insert the extended wires in between those buttons and their own connectors.
To clarify, I mean cut the green plug off the end of the wires attached to the 2 sets of climate control buttons, solder in the extended wire then solder the green plug back on.
The bonus is you don't have to actually be in the vehicle to do it this way.
Old 12-19-2018, 03:59 PM
Received 8,575 Likes on 6,626 Posts
Yeah.. don't use undersized wires
2. Don't cut live wires
AlexTheMan
1G TSX Problems & Fixes
11-12-2013 12:57 PM
jblessing
07-01-2012 12:09 PM
spyked
06-01-2012 01:44 PM
aar0n
1/2G MDX (2001-2013)
07-11-2010 10:58 AM
Riga89
04-26-2010 12:16 PM
Quick Reply: HVAC and Radio display gone dead - need help
