HTC EVO 4G won't connect
Anyone had any luck getting an EVO 4G to connect to Hands Free Link? My 06 Non Nav doesn't seem to be found and I have heard stories that some connected with no problems at all and others had the same experience that I have had. Thanks!
what steps are you doing to connect it to the car?????? is it giving you any errors on the phone or the car?
you should be following the procedure at the link below. Choose you car then the phone model and it will give you step by step instructions.
http://www.acura.com/handsfreelink.aspx
single_dad_73 (08-26-2011)
Thanks Garrett! I can connect my sons cheap flip phone but my EVO could not be discovered for some reason. I will try that at lunch and let you know if it worked.
navtool.com
31
11-16-2015 08:30 PM
