HTC Droid Incredible HFL Pairing Success TL 04
I was able to successfully pair my new HTC Droid Incredible (a Verizon Wireless smart phone) with my 2004 TL. No problems during pairing.
I get signal strength & battery level on the multi-info display.
I was able to initiate a call from the HFL after pairing. One small glitch so far is that any time I start a call (or end a call), I get a couple moderately loud "pop" noises through the audio system. I had this same problem with my last phone (LG Voyager).
I'm just happy that I was able to pair the phone.
I have successfully paired my HTC Incredible to my 05 TL (Non Nav). Best and easiest way to do this Set your Incredible to discovery mode. Set up the pairing process with the HFL. Select 0000 or whatever for your pin. When the HFL starts looking for available devices it should find the Incredible. If it dosent on the first time then do the HFL pairing process again. Next time it starts to search for a bluetooth phone go to the incredible and scan for devices it will find the HFL select it and it will ask for the code you set. Enter the four digit code, name the device in the HFL and boom your done.
having issues pairing 1st generation droid with 2004 TL, phones gets all the way to finding HFL on car , asking for code used on car, phone finds car but car does not id the droid, any suggestions?
Go into the setup, remove any phones that have been paired in the past. could be a conflict with a previous device. I remember doing that and it finally worked.
ExcelerateRep
10-14-2015 08:20 AM
SinCityTLX
10-07-2015 01:24 PM
phillyguerrilla
09-26-2015 11:27 AM
09-25-2015 06:14 PM
2005, acura, bluetooth, compatible, droid, free, hands, handsfreelink, hfl, htc, incredible, link, pairing, problems, tl
