HFL W/Motorola V600
Old May 7, 2004 | 04:12 PM
waymay1305's Avatar
HFL W/Motorola V600
Question? Once the phone is placed in the discovery or Bluetooth mode, how long will it remain in that mode without actually using the HFL? I'm concerned about putting the phone in that mode to accept incoming calls when it may be at least 15 or 20 minutes before I actually receive a call. It sort of defeats the purpose of having the HFL if the phone is going to program itself out after a set period of time. It seems to be very tedious to have to continually put the phone in the Bluetooth mode if you don't receive any incoming calls.
Old May 7, 2004 | 04:18 PM
user 37364638's Avatar
BOOK EM
Program it, then forget it. That`s how my T 616 works
Old May 7, 2004 | 04:19 PM
automata's Avatar
ImayBparanoidButNoAndroid
Are you saying that the phone disconnects from the HFL after a while? If you connect to the HFL it should stay connected no matter how long you go without getting a call.
Old May 7, 2004 | 04:28 PM
TXTL's Avatar
correct
automata is correct. as long as there is a bluetooth connection between the V600 and the car it will stay connected. When I shut off the car, the V600 will look for a bluetooth signal for 60 seconds then it turns off. When I turn the car back on, it auto reconnects. Hope this helps!
Old May 8, 2004 | 01:43 PM
cullal's Avatar
Works for me just as TXTL said... Also make sure that you plug the V600 into the car charger. The bluetooth sucks the battery on the V600...
Old May 8, 2004 | 01:58 PM
SlntSam's Avatar
Same, I've only run into minor problems, nothing to complain about.
I think being connected via bluetooth drain the battery more though.
Old May 8, 2004 | 03:44 PM
smoore's Avatar
If you don't leave the phone in discovery mode I don't think the car will detect the phone the next time you get in the car.
Old May 8, 2004 | 04:29 PM
nfnsquared's Avatar
If you listen carefully you will hear phone make a beep/tone when it drops the bluetooth search.
Yes, the battery life sucks when the bluetooth link is active. I always leave the phone plugged in when in the car. Not sure if there is a "memory" issue with these batteries.....
stogie1020
Cameras & Photography
Sep 28, 2015 10:45 AM
phillyguerrilla
Sep 26, 2015 11:27 AM
rmittal
1/2G MDX (2001-2013)
Sep 19, 2015 08:41 PM
cali boy 91
Sep 19, 2015 01:57 PM
Markbby06
Sep 17, 2015 02:30 PM
