HFL messed up I think help!
was that a statement, a question, or just confusion?
Registered but harmless
Received 1,149 Likes
If the HFL hasn't started working again after 2 or 3 ignition cycles, it's probably bad and will need to be replaced. The HFL is @$180 now. A DIY HFL install is a very easy 10-minute job if you've got normal hand dexterity and coordination.
The useful info starts around the middle of the thread, or about post 160, here: https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/bluetooth-fails-792642/.
Welcome to AZ.
Welcome to AZ.
2004 TL HFL not working
I have a 2004 TL and the HFL bluetooth quit working about a month ago, stuck in booting and locks up radio, had to pull battery cable to reset radio. I found a replacement unit from DCH Honda of Termecula for $159.81, received in and installed it last night and now am back in business.
Part number is 39770-sep-305zc-acura
http://www.dchautomotiveparts.com/
Handsfree Link Needs Servicing
When I run the diagnostics on my HFL I get a message that the Handsfree Link needs servicing. I'm guessing I will need to replace the unit but wanted to check before I did. I'm not to happy about this since I all ready replaced it once.
Thanks,
Gordon
06TL/Nav
Thanks,
Gordon
06TL/Nav
emailnatec
29
09-28-2018 04:27 PM
phillyguerrilla
09-26-2015 11:27 AM
