HFL Failure after iSimple install
This could be unrelated and I haven't had time to remove the iSimple to see if that makes a difference.
About 3 months ago I installed the iSimple and a few weeks ago I tried to pair a phone to my HFL and it would't respond at all when I pressed the button on the steering wheel to activate the HFL. Over the next several days I tried pressing the HFL button each time I drove the car and no luck. I even tried restarting the car multiple times as well as having the Radio head unit turned to different modes (FM/XM/CD) and having it turned off all without working. After about a week I finally got it to work but the next time I started the car it would not work. Same thing happened this week except it also worked on the next car start but not after that.
Wanted to know if anyone else has experienced HFL problems after installing the iSimple?
nope
Likely just a 3-month later "coincidence"...I'd say your lucky the HFL lasted well into 2012.
If you had it installed 'professionally' you need to check if they wired it correctly. They blew my HFL, amp and my entire dash out by wrapping the wire around a fuse and sticking it back in. Instead of running it to a free port and putting a fuse in it.
My HLF lasted well into '12 until that happened!
My HFL does the same thing. Sometimes the button will activate the HFL and i can try to sync a phone (it nevers finds my phone though) and sometimes i hit the button everyday for a few days and it wont do anything no matter what I try. Its not the iSimple i'm sure.
Chapter Leader (Arkansas)
My gut tells me you have an issue with the HFL, not the iSimple. Have you touched the HFL to see if it's warm to the touch? My went out this year (2012). Are you noticing any battery issues (i.e., car not starting)?
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/hfl-module-replacement-06-tl-843512/
After you have it parked for a while (maybe an hour or more), go out and feel the plastic piece by the rear view mirror. If it is warm to the touch (you will be able to tell), you probably have a bad HFL. When it starts to go, it typically goes into a "loop" mode, where it runs on its own, even when the car is turned off. Mine starting going and eventually drained the battery (documented by many on AZine). My steering controls also did not work at all (like you).
If the HFL worked after you sent off and got back your head unit, you could probably eliminate the head unit. 'Trying to help where I can...eliminate and move on to something else. I hope you get it figured out soon.
Buda (11-12-2012)
Thanks, I went ahead an ordered a new HFL unit. I just found that thread you referenced as well. Pretty sure mine is bad. I should have known it was up there. I 3M dinoc'ed the overhead console so I've been in that area before.
I'm pretty sure it's just a bad HFL unit just like everyone else's. Will post up when I get the new one installed. Also took the opportunity to order the part to do the shaved door handle mod.
Buda (11-12-2012)
I think Im having the same problem, my HFL stopped working about a week ago but I havent had time to diagnose it yet... 2 days ago, after my car had sat for about 3 days, I went out to start it and it was dead, only 9.2V at the battery... I didnt even think about the HFL being the culprit. If I just take out the roof console and remove the HFL unit thatll prevent the battery draining I assume?
mada51589
05-03-2022 08:54 PM
Vejey Gandier
09-12-2015 08:59 PM
