HELP! w/ LED Floor install
Old Jan 10, 2008 | 02:48 PM
MightyTL's Avatar
06 TL! / 05 R6
Question HELP! w/ LED Floor install
I am going to be installing LED lights for the floor...
BUT, Where can I get a power signal that turns on when I have the headlights on?
Just so I can have this installed w/ haveing the LED go off by it self when the headlights are off and the LED turning on when the headlights are on.
Anyone got any ideas???
Old Jan 10, 2008 | 02:50 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
You should be able to pull power from any of the dash lighting as it turns on and off with the headlights.
Old Jan 10, 2008 | 03:01 PM
phee's Avatar
I got the Shifts
make ceartain not to wire anything incorrectly, i ruined my dash lights doing an LED install, now i cant see my speed at night.
Old Jan 10, 2008 | 03:03 PM
aSPECtL06's Avatar
I wanted to do this too but I think I'm going to get it done professionally in Long Island.
Old Jan 10, 2008 | 03:15 PM
6MTUA5's Avatar
No He Can't
I fried my ECU doing the door handle LEDs.
Old Jan 10, 2008 | 06:15 PM
THTL's Avatar
how does the door handle leds turn out.
Old Jan 10, 2008 | 06:23 PM
KB1Spec's Avatar
Are you referring to installing the LED under the driver and passenger side dash? If so you can run a power source inside the armrest storage. There is a light source there. When you turn on the headllight it will light up and when you turn off it will turn off.
Old Jan 10, 2008 | 08:02 PM
Kennedy's Avatar
OMGWTF4THGENTL
red wire, black stripe, two silver dots = positive illum.
black wire = ground.
It's that easy...
Anything that lights up at night has these wires... splice into them.
Old Jan 10, 2008 | 10:48 PM
MightyTL's Avatar
06 TL! / 05 R6
I was talking about the front floor... Right above your foot...
Old Jan 10, 2008 | 10:51 PM
MightyTL's Avatar
06 TL! / 05 R6
It's that easy...
Do you know any area in the car you see these easy wires? I was hoping to find some near my foot area...
Old Jan 10, 2008 | 10:52 PM
MightyTL's Avatar
06 TL! / 05 R6
How?
+ to + and - to - ?
Old Jan 10, 2008 | 11:47 PM
bignoodleboi's Avatar
https://acurazine.com/forums/showthread.php?t=41187
I did this to my car and i wire the wires to the Cubby light so it turns on when only the dash lights comes on... so i guess the TL has something similar to this too... if you guys scared to mess it up put a relay circuit on it with a fuse to be sure :-)
something like this?
Old Jan 11, 2008 | 01:29 AM
BLACKURA_NY's Avatar
I have car ADD
looks good... .red = ugly
biggest downfall of the TL-S
Old Jan 11, 2008 | 01:30 AM
MightyTL's Avatar
06 TL! / 05 R6
Yes! Exactly! Very NICE!! Shoulda got the blue... I got the white strips.
Old Jan 11, 2008 | 01:31 AM
MightyTL's Avatar
06 TL! / 05 R6
Why? it has red floor lights on the TL-S?
Old Jan 11, 2008 | 01:34 AM
MightyTL's Avatar
06 TL! / 05 R6
Whats a cubby light? sorry...
Also got any pics of the splicing? just want to know where abouts I can splice in.
Old Jan 11, 2008 | 01:51 AM
oh on the TSX theres a storage under the radio and when you open it theres a little small light that shines thru... i dont know about the TLs... sorry... but i guess there would be a little light area for other places that you can tap into or splice...
sorry i dont have any pic of the splicing but on the TSX i just tap into the BLACK(negative) wires and the RED/BLACK(positive) wires
Old Jan 11, 2008 | 02:00 AM
white strips for your teeth? haha JK i just one LED on each side dont want it too bright where it doesn't look factory
Old Jan 11, 2008 | 12:33 PM
MightyTL's Avatar
06 TL! / 05 R6
Hmm.... Anyone know where I can tap into for the blue light above... The light next to the garage opener button.
Couldnt find any DIY on it...
HELP?!?!?!
Old Jan 11, 2008 | 12:55 PM
bluenoise's Avatar
HELP?!?!?!
The two blue LEDs in the overhead console are surface-mount devices and are part of a printed circuit board. Tapping into that would be pretty risky compared to directly into a wire. That said, you should be able to find the wire that feeds the circuit board and tap into that.
I am guessing the wires up there match the same color coding as was mentioned earlier in this thread. It's easy to confirm all this with a circuit tester, though.
Old Jan 11, 2008 | 02:09 PM
MightyTL's Avatar
06 TL! / 05 R6
I wanted to avoid all of that and was trying to take the easy way out...
I guess im going to have to goto to radio chack and pick one up... and start investigating...
Thank for your help tho...
Old Jan 12, 2008 | 02:22 AM
MightyTL's Avatar
06 TL! / 05 R6
Just to let you guys know I used the Trunk opener light....
Also if you blow a fuse change out the small ligh fuse (10) under the hood.
Old Jan 12, 2008 | 09:47 AM
Kennedy's Avatar
OMGWTF4THGENTL
HELP?!?!?!
As I stated earlier... All buttons that are illuminated have the illum wires. You can also tap off the little interior illum wires in the glove box.
I tapped my blue footwell lighting into the trunk release button on the left, and the glovebox illum on the right.
Old Jan 15, 2008 | 08:11 PM
jumbosizeme79's Avatar
aTLien
i was looking @ some pics n i also saw the led bar lights under the back seat, any idea how to connect n install?
Old Jan 16, 2008 | 03:46 PM
KB1Spec's Avatar
here you go:
https://acurazine.com/forums/showthr...0&page=1&pp=25
Old Jan 16, 2008 | 10:35 PM
Tonywp75's Avatar
Dont Touch My Car !!!
Wiring up LEDs is pretty easy. They are much better then the CCT. I have wired up CCT on the footwell and used flexible led strips on the door. I tapped into the door light and doom light. So when i unlock my door the leds turn on and when i open the door the lights turns on. They only turn on with the factory light. Ididnt want the light to stay on.
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
BoricuaTL
Apr 8, 2016 01:08 PM
EE4Life
Sep 11, 2015 10:13 PM
