Help me connect my v710 to a TL
I've bought my v710 about a week ago and have been trying to connect it to my Navi TL and even though I've read through the instructions I just havn't been able to connect the two. I'm about to burst cause i'm not that illiterate with technology but I think i'm just doing something wrong.
Please Help....Just give me a short concise list of what to do to both the TL and the V710 to get them to recognize each other.....
Thanx,
George
Thanx,
George
Cesspool of Knowledge
KG - It's not too difficult.
Good Luck!
Note: If this still fails, let us know where the problem occured at. We'll get you going ... I promise!
- Have your TL stopped with the ignition in the Accesory Mode - you can't pair the TL while the car is moving.
- On your V710:
- Menu
- 7 (Settings)
- * (Connection)
- 1 (Bluetooth Link)
- Setup ... Now wait before pressing "Find Me", which will occur below.
- On the Acura HFL:
- Press the HFL Command Button (HFL Com)
- Say, "Phone Setup"
- Press HFL Com
- Say, "Pair"
- You will now get prompted for a 4-digit code by the HFL system.
- Press HFL Com, and say your 4-digit code.
- Now, it's time to wait again (Don't confirm your code yet ...)
- On your V710:
- Select "Find Me" on the phone. The V710 will now be visible for 60 seconds.
- On the Acura HFL:
- Press HFL Com and say, "Yes" to confirm your code.
- On your V710:
- You should now be prompted for the 4-digit code that you just spoke to the Acura HFL. Enter the same code on the V710, and press "OK".
Good Luck!
Glernson
I have a quick question. I just paired the phone with the HFL today. It seems that whenever I am in the car and the bluetooth is synched, the front display on my phone stays lit. Is this the case for everybody. I am thinking that this is going to shorten battery life considerably. ( if not on charger)
Thanks...great phone,great car
I'll try to remember to check again, but I think that I was concerned about this myself before, and I'm not worried now.
I just got my V710 and used the instructions in the thread to connect to my TL. Everything goes as described until the end. The V710 never gets recognized by the TL and I never get the prompt to enter the code into the V710. Any suggestions???
Thanx,
George
Thanx,
George
GotJazz made one little mistake (which lots of TL owners can do easily because the TL prompting is actually wrong)
DON'T:
Menu
7 (Settings)
* (Connection)
1 (Bluetooth Link)
DO:
Menu
7 (Settings)
* (Connection)
1 (Bluetooth Link)
Handsfree ... Now wait before pressing [Look for Devices], which will occur below.
Team Camel Executive VP
When the phone is placed in the TL and the engine is started, the display lights just as if you'd opened the phone. Then it'll go dark and remain paired.
BJ
Originally Posted by boltjames
The phone will stay lit for whatever time period you've specified it to remain lit in the Menu>Settings>Initial Setup profile.
BJ
BJ
Originally Posted by fro
Agreed. I've used my V710 with the headset I carry around when away from the car. Seems to drain the battery about 20% faster than if you do Bluetooth power-off. So it does reduce battery life, but I wouldn't say it's considerable. If you're unable/unwilling to charge every couple of days, then shut Bluetooth power off when not using it. For me, it's not that big of a deal.
The TL's upper/lower armrest with power port and passthru is the perfect location for one of these too:
Costs under $20 and that blue "M" logo lights up a bright green when plugged in, creating a nice nightlight effect in the lower armrest
BJ
8th Gear
KG,
DON'T:
Menu
7 (Settings)
* (Connection)
1 (Bluetooth Link)
DO:
Menu
7 (Settings)
* (Connection)
1 (Bluetooth Link)
DON'T:
Menu
7 (Settings)
* (Connection)
1 (Bluetooth Link)
DO:
Menu
7 (Settings)
* (Connection)
1 (Bluetooth Link)
I assigned a simple shortcut to the Bluetooth power option, so I'm only two button presses away from the on/off switch.
BJ
BJ
I bought one of those chargers off of ebay, but since the holiday, I would have to wait for shipping.. I just spent over $100 on accessories at the verizon store yesterday .. extended battery / case / car charger / two ear jabra headset things.
Originally Posted by gwp
Just got my V710 and followed the thread directions with the revision. The phone pairs with the TL but I never get asked for the code (by the phone). The phone is not automatically recognized by the TL the next time I use the car. I have to do a new handsfree search every time I get in the car. Any ideas?
In order to get the BT connection set up, you must have had to enter the PIN code. After doing Look for Devices, the HandsFreeLink should show up in the Scan Results list. Then, you press the Select key (right softkey) and after a few seconds, you will be prompted for the PIN code.
To answer your second question, you do not need to do handsfree search every time. The HFL should go out and try to connect with the V710 when you turn on the ignition.
You can also force the 710 to connect with the HFL by selecting it from the Handsfree menu....of course this assumes you've successfully paired the V710 and HFL at some point in the past and haven't deleted the V710 from the HFL's device history or vice versa.
Originally Posted by someone
How did you make your shortcut, I am still learning this phone and the damn car too .
Creating a shortcut
1. Navigate to the item that you want to make a shortcut for (e.g. menu>Settings>Connection>Bluetooth Link>Handsfree)
2. Press and hold the menu key for a few seconds.
3. You'll get a prompt that allows you to name the shortcut & key it's associated with. Make whatever changes you want, or accept what's been filled in for you already.
4. You'll then get a brief window stating 'Shortcut assigned: "OK" + "3"' or something to that effect.
5. Now you're done & can simply press "OK" followed by the number of your shortcut to get there.
Use "Home Keys"
Since I use Bluetooth a lot, I defined one of my home keys to take ne to the Bluetooth Link menu. 1. To re-define one or more home keys, do menu>Settings>Personalize>Home Screen>Home Keys.
2. Pick a key (up, down etc.) to change and hit the "Change" softkey.
3. Pick a new function to assign to that key from the list.
You're good to go!
There are a couple of ways to save yourself some keystrokes....you'll have to figure out which one you prefer.
Creating a shortcut
Use "Home Keys"
You're good to go!
Creating a shortcut
Use "Home Keys"
You're good to go!
Awesome, I set it for #1 and couldnt figure out how to hit the number 1 for it. Then I messed around with it for about 10 minutes and figured out to leave the "up" arrow for "shortcuts" and that lists all the shortcuts. Thank you very much.
Tried that .. and it's not working. You're talking about the OK button that is in the center of the directional pad right? I press that then 1 .. tried with 1 2 and 3.. and different combos.
navtool.com
31
11-16-2015 08:30 PM
