Help with deleting old GPS data
I have an 05TL auto with navi using the standard version it came with. Im having a problem deleting all of my previous destinations data stored in memory. I can highlight each one and delete manually but whenever i return to previous destinations list the addresses are still there. Its either a glitch or im missing a step. Someone please help as i need to delete this stuff. Thanks.
Registered but harmless
Received 1,147 Likes
The instructions are on p. 51 or 53 of the Navi manual.
1) Go to "System Setup" using the System/Info button to the left of the Navi joystick (or say "system setup" using the voice controls).
2) Select Tab #2 in system set-up, then select "delete previous destination" about mid-way down.
3) Select "all address" to delete all addresses.
Do NOT select "cancel" if it appears-- that will cancel the deletions.
rockyboy
01-25-2016 06:00 PM
DerrickW
11-15-2015 05:52 PM
johnpancakes014
09-27-2015 12:58 PM
2011, acura, address, data, delete, destinations, destionation, erase, gps, information, mdx, previous, rdx, tl, user
