Has anyone swapped radio with HVAC?
Has anyone ever swapped the headunit with the HVAC? Just wondering how hard it would be because it just seems a bit low for gps and back up camera use.
doesn't sound like a good idea for the reasons you listed
Oh.. you're talking about an aftermarket head unit
disregard
disregard
You would probably need to extend some wires. The problem is that rest of the console is shaped like those panels, meaning wider at the top, and silver trim going around volume knob.
Making it look nice would be the main problem.
Additionally, there is no much room behind the HVAC panel, so if your head unit is long it won't fit.
There is a brace in behind the Nav screen. When I installed mine, I got it as high as possible without cutting and making another brace.
I also used a head that is a double din front, but actually a single din behind. Check out the mock up pics I posted.
Well I’m really most interested in relocating just the display not the buttons .. and I already planned on doing custom trim panels to remove the volume knob cutouts
That come out pretty awesome.. what exactly is you add/ delete/ switch around? And how did you mount the headunit up higher? Also mine is non nav so im Not sure if I have the plastic piece you added the 12v plug to
The piece below the head is made of lexan, I made it to mount the bass control and the USB/HDMI plug.
yosarian
06-15-2007 05:12 PM
maevonee
12-14-2002 02:17 PM
