Hardwiring FM Modulator into Rear Antenna
I looking to hardwire a FM modulator into the rear antenna. Does anyone have any idea where the wire is and if this can be done? If not does anyone have directions for removing the radio in order to access the antenna?
You can't do it. The rear antenna uses a mini plug. I tried it through the back and it does not work. You have to go through the back of the radio. I know this because I have done it. Buy a service manual to show you how to get the radio out. Dont try it with out one because you will probaly break something. Good luck!
09-17-2015 09:01 PM
oyayjoe
09-12-2015 04:40 PM
