Handfree Link and Call waiting
Just linked a v710 no problems other than the display does not show info other than caller ID as noted in other posts. Does anyone know how to answer a call waiting tone and switch between calls when connected the Handsfree link?
Simply hit the Talk button to go from the current call to the incoming call. Then hit the Talk button again to return to the first call. If you wish to hang up from the current call to accept the incoming call, press the Back button.
NB. I haven't tried it yet, but in theory (at least from the Acura's manual), that's the way it's supposed to work.
I found a solution to the question. You have to switch calls by hitting the send button on the phone. This works even when you are on the HF Link. However, you can not see the caller ID of the second call on the dashboard.
