Got Dom's PnP w/ a Backup Camera? STEP INSIDE...
Fearless DIY Guy
Wow, so things have been going anything but smoothly as of late. So, I installed Dom's PnP with a Boyo backup camera, which seemed like a relatively simple install that most anyone should be capable of completing...well, most anyone except those with exceptionally crap luck, such as myself.
So, here's what's going on: I completed the install as normal. White, white, black, green to ground; red to switched source (Fuse #32), and blue wire to backup camera...right?
The boyo backup camera has two leads - video and red (power).
So I tap off of the switched source which leads in to a relay; the relay is triggered from the reverse light, which then powers the BLUE wire on Dom's unit and the backup camera.
I do that, and BOOM fried fuse. If I disconnect the camera and throw it in reverse, the nav screen goes black, which tells me that Dom's unit is doing what it should be.
Any thoughts as to why this is happening?
hmm try everything without a relay. I did not use a relay in my setup.
I just had the blue wire from DOMs connected to the Green reverse Light wire.
I Also connected my reverse camera power wire to the green reverse light wire. I spliced both wires into the green reverse light wire at the same place.
No relay for me. But sounds to me like your relay might be wired incorrectly or is bad. Sure you have all the leads wired correctly? I would first remove the relay from the equation and see if it works.. (I do know you know alot about your wiring from your other threads, but maybe it is a bad relay?)
When i did this it sucked because of all the freaking wires lol ..
Fearless DIY Guy
When i did this it sucked because of all the freaking wires lol...
Thanks for the suggestion, I am going to try this out tonight.
You gotta love modding!
I have the NavTool installed for about a year now. I can't remember my wiring, but it sounds similar to what the other guys are saying. I remember I had trouble getting my cam to display until I tapped the reverse lights---just don't remember which wire it was.
You didn't happen to take pics of the HID reverse lights install, did you?
Fearless DIY Guy
Yah the mess of the reverse HIDs, CCFLs, reverse camera and DOMs was a pain for me to clean up lol .. Im afraid to remove the covers to see the ugly mess behind there .. lol .. almost impossible to make look good.. well at least for me.. lol
Cant wait to see your progress pics man!
I knew it should have a ground!! lol .. IM suprised they didnt cut enough back so you could see both wires! Now get this thing installed! I want to compare the quality of this camera with the camera I got..
Only thing that sucks about installing the rear view camera is that the CCFL license plate lights are sorta blocked by the camera.. so not AS bright.. but still bright!
Like I said before cant wait to see the installed pics!!
Here is one of my Boyo VTK350 installed:
Be careful when dremeling out the plastic (and you will have to dremel it out a bit) as the heat can melt the plastic a bit. You can see it just above the camera. Acura does not sell just the brushed chrome plastic piece by itself---you have to purchase the entire Plate/Reverse Light housing for ~$250.
Here is another shot showing how I ran the cable:
Pop out the license plate light, notch it with a dremel, paint the bare metal with touchup paint, then take a network cable or similar and strip a bit of the plastic sheathing to glue over the cut (helps prevent cutting of the insulation on the camera wire).
Just passing along some experience.
Here are pics of my camera deathmetal.. You can see how I ran my wires.. I drilled a huge hole by accident because i bought the wrong grommet. Ended up having to use elecrical tape wrapped around the wires and push it through the hole to protect the wires and prevent water from going into my trunk.. you can also see my ccfls in these pics.. dunno if this will help, but doesnt hurt!
Depends on how the CCFLs are mounted, I guess. I thought guys were mounting them inside the trunk lid, shining through the OEM holes. If that is the case, it should work okay as the lenses pop right back in and are even watertight (I tested).
edit: you posted your pics while I was writing. DOH!
Fearless DIY Guy
Guys, I am having NO FREAKIN' LUCK HERE.
So everything is wired as 'should be', and no fuses are blowing...but the only thing that is happening is the camera will turn on ONLY when the ignition is on and car in reverse...when the car is started, and put in to reverse, I get a slew of green lines and a black screen.
I am running out of ideas now. :wtc:
Fearless DIY Guy
I drilled/dremeled as well, fellas...new hold as to ensure the CCFLs kick some real ass...which they, and the reverse HIDs do.
...now if I could get this camera things resolve...
I am starting to think something is wrong with Dom's unit.
Sounds like a possible ground issue. I know these video units can be sensitive to improper grounding---mostly with faint lines in the screen that scroll vertically. Double check all grounds to make sure you are grounding to a non painted, fresh surface. I have also heard that it is bad to use OEM grounds or any other shared ground location. The stereo guys attribute noise to this factor a lot.
To answer your question, my cam activates whenever Im in Reverse--engine running or not.
Try a different video cable? Or try plugging in a different source, like a dvd player into the RCA plug for the reverse camera.. This will tell you if it is your DOMs unit OR your reverse camera causing the problems.. I had the same problem at first.. Then I changed to a high quality video wire.. and everything worked fine..
Are all the grounds on your DOMs unit grounded well? Does the other video input in your doms work correctly? (the one you can activate with a switch?) Try attaching your reverse camera to that plug instead. when you go in reverse your camera should show up on the screen when you flip the switch..
Fearless DIY Guy
BZ, not only does your car inspire me, you've solved a problem I spent over 10 hours attempting to resolve.
Looks like it might be the camera, DVD player fires up fine.
Many, MANY thanks.
Many, MANY thanks.
Well if it is the camera, I would try a few things.. what did you ground the camera wire too? Try testing your camera with a tv if you have one that you could bring to your garage.. connect the rca to the video in of the tv and connect the ground and the power to the battery terminals.. if it works good, then it is either your ground that you were using to wire your camera or the video cable you are using needs to be better..
No problem man!! I intend to hit you up if I ever decide to do the interior led conversions you did! Now those are a work of art!
btw.. i grounded my camera to the black wire from the reverse lights and powered mine up to the green reverse light wire.. try this! and get yourself a bad a$$ shielded video wire! I purchase some high end quality audio wire from radio shack for 15.00.. worked great in my case..
Fearless DIY Guy
Well, I tried grounding directly to the chassis and SOLDERED it to the chassis...and only the slightest of flickering, then crapped out. Something is wrong with this thing.
Good thing I got that square trade warranty!!!
Still on sale!
http://www.amazon.com/Audiovox-ACA20...CJFCAT2161EARV
Fearless DIY Guy
I think you'll change your mind once you see how I installed the boyo...
Ahhhh, well, at least this nightmare is kinda/sorta resolved...at least I can button up the side of the trunk for now and move on to the subs while I await to resolve this issue with the camera.
OH, BZ - if you're going to do the LED thing anytime soon, DON'T use a 680-ohm resistor for white LEDs...they're dying something feirce, I need to up the resistance to 1k (all 1K LEDs are juuuuuust fine)
No, I wont be able to do the LED swap for awhile.. maybe like a year awhile lol...
Joe Avesyan
09-29-2015 03:57 PM
