Getting Bluetooth to Let Go?
I have a Treo 650 that I'm using with HFL. It works great, except for one thing.
I actually use the navigation system in my Treo 650, which uses Bluetooth to connect to the GPS. How do I get the Acura to let the Bluetooth connection go so that I can use my Treo with other bluetooth devices (the headset for a private call, or the bluetooth GPS)?
No matter what I do - security lock it, reset the Bluetooth on my phone - it still locks the connection to itself.
The only thing I successfully did was delete the phone. Unfortunately, the HFL system has a bug in it where it doesn't *really* delete the phone, it just removes it from the list of phones. I you try to re-add the phone, the HFL system crashes and you have to completely clear it (losing all your phonebook settings, etc.) to re-add the phone again.
The 800 number at HFL refuses to admit the "delete" bug exists in their system (even though I tested it on my friend's Acura with a supported phone and it still happens).
Anybody have a good solution for this problem?
Welcome to the forums. As far as your question - in your treo - can't you set the GPS BT unit to have priority over the HFL? Some phones do allow this - but I am not sure about the treo.
Originally Posted by crazymjb
Sorry, no. But I am confused about what you mean by you use it with the nav. Dont mean to pull this thread from the original question.
That is correct. I use the navigation built in to my phone (the PalmOne Treo 650) rather than the nav on the Acura.
Leaving aside all the complexity with that, my question is this: "how do I tell the Acura to let go of the connection with my phone so I can use another bluetooth device with the phone?"
The idea about trying to find a connection priority capability in my phone is a good one. I'll try that, it may work.
05/5AT/Navi/ABP/Quartz
On my Nokia, in the Bluetooth Menu, I can disconnect the HFL connection. Try drilling down through the Treo menus if that would accompolish your goal.
MetalGearTypeS
08-29-2016 08:28 PM
InFaMouSLink
10-30-2015 09:43 AM
SUPRMN84
10-07-2015 09:46 PM
