Factory sub & amp???
3rd Gear
Is it possible to put an aftermarket sub in truck but have it wired to the factory amp so I have sub control and maybe a little better sounding bass?
You will never be happy with the sub output using the factory amp. You can add an amp and sub and still retain sub control from the HU.
^^^How to what?
What the others have said, however you can use the signal wires before or after the amp and route them to an aftermarket amp via a Line Driver or Line Out Converter, which will still give you control of the sub volume via the head unit.
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
