Enabling trip computer on TL natively
#81
Originally Posted by brianp6621
OK, I just completed this at lunch. It was very simple.
Regardless, this is a very cool/easy hack.
Now here's hoping for the OK button removal.
/AngryDad
#82
PCM full of water, yummy
Some info:
06 Accord-
17.1 gal gas tank
205/60 R16 tire size, 25.68" diameter, 809.9 Revolutions per mile
215/50 R17 tire size, 25.46" diameter, 816 Revolutions per mile
06 TL-
17.1 gal gas tank
235/45 R17 tire size, 25.32" diameter, 821 Revolutions per mile
Don't know if this will help, but maybe...
I'm guesing that the tire size has to be known, in order to get the correct miles, kind of like when you put super swamper 33's on a toyota pickup, you need to recalibrate the computer for the correct tire size, or else your mph will be off... and also miles traveled will be off.
06 Accord-
17.1 gal gas tank
06 TL-
17.1 gal gas tank
#83
2004 SSM/EB/5AT/Navi/RSB
It works! Though I have the 3.30, I put in a patched 3.50 version and used CEBin to repack the BIN file.
When in the Trip Computer, the voice commands are dinked. For example "XM Channel 150" seems to ask for the current time and "XM Channel 45" turns off the "Reset with Refuel," or whatever that is. The quick workaround to this is to hit the AUDIO button, say the TL voice command you want and then hit the AUDIO button again to go back to the trip computer.
While I'm bummed the resolution is only 5 MPG, it's still pretty useful for seeing how fuel use is affected by various factors.
Thanks, AngryDad, for making this so easy!
#84
This site is filled with talented members willing to freely share their knowledge with others. Unfortunately, allowing a link to be posted for donations goes against this idealogy. Therefore, AngyDad's donation link has been removed.
Thank you all for your hard work and dedication. This is what makes this site so great. Let's keep it up.
#85
Originally Posted by kennyc
I extracted bnhh401a.bin and tried to patch the HMIManager.exe and I got "CRC check failed. Ignore?"
I click on "yes" and it came up with "Data mismatch. Ignore?"
I stopped here...
I do have the 3.5 disk (orange)
Thanks for doing this!
I stopped here...
Just letting you and others know that I got the same exact "CRC check failed" warning during step 11 in Wyzard's instructions. It gave me 4 to 5 different warnings in a row. I kept clicking "ignore" and eventually got a message saying it was complete. I burned the 9 files to a cd and used it and works without any problems.
#86
not vtech... VTEC!!!
hmmm.. I got that message b/c I was trying to patch my HMIManager.exe (3.40c) with AngryDad's patching program (for 3.50)
No more crc errors when I used his prog and patched a 3.50 HMIManager.exe
#87
JCR69NYC@YAHOO RL NAVI 05
Goodies
Thanks goes out to AngryDad and datmrman. I edited out some stuff out of the HMIManager.exe from the v3.50 and was finally small enough to fit in the v3.40c bin!
Here are some pictures of the new screens...
I am currently working on finding a place to host the patched HMIManager.exe file. It should be up shortly.
Thanks again! Keep up the great work!
#88
1 Post
Will someone please confirm for us....
The instant mileage "chart" shown above...it is indeed in 5 mph increments. But does the indicator jump in 5 mph increments? Or is it smooth and will display a value in between the numbers? Kind of like a clock with only numbers every 5 minutes. The clock will display minutes in between the numbers, you just have to figure out yourself that it's 7 minutes after because there are no hash marks in between the 5 and the 10...the clock doesn't wait 5 minutes then "jump" to the 10. Is this the same way? It doesn't jump between the 5 mpg scale does it?
#90
It does jump in 5 MPG increments, unfortunately. While I was driving home from work last night, it was jumping between 30, 35, 40, and 45 MPG while I had the cruise control set at 72 on level, straight freeway (San Mateo Bridge). Interestingly, it tended to hang out in the 35 and 40 slots the most. When I raised the CC setting to 75, it spent more time between 40 and 45 MPG. I guess the engine runs more efficiently at the slightly higher RPMs such that the additional wind resistance wasn't enough of a factor to hurt the mileage.
#91
I wish it had 1 MPG resolution. In the diagnostics mode, there is a page showing trip computer raw information. There is an entry for speed (mm/sec) and an entry for fuel usage (ml/sec). Doing some simple math on those two values returns instantaneous mileage. It's too bad they chose to limit the resulting resolution for the TripComputer display.
#92
Originally Posted by bluenoise
It could be that the HMIManager is just calling external applications and this hack modifies it to call the TC application. Though the HMIManager getting patched is the TL version, the TC may not be. The TC application may be somewhat universal to Accord and TL, but it may not be reading in some TL-specific information, such as tank capacity. Perhaps there is a data file that gets read by TC which contains all the vehicle-specific information.
Angrydad?
#93
And I have started to keep detailed records of the 2 trips computers. Basically every time I get into my car I record the current status of both trips and I am plotting the numbers in excel. I will will post more when I get more lengthy info.
#94
#95
1 Post
it does "jump" in 5 mph increments.
#96
Originally Posted by CobraGuy
That makes this hack damn near worthless to me then. Too bad too because I was about to do it. Many thanks to AngryDad for all he did to write this, but it looks like the software engineers at Acura beat you out of what should have been an excellent result.
Also, the resolution of the averages includes one decimal place. This is much higher resolution than the MID shows.
#97
'06 NBP : 6MT : NAVI
angrydad,
If you don't mind my asking, what program are you using to determine where to edit/patch the .exe files?
I was looking at the blocks that you modified to enable the extra features, and my hex editor just showed nonsense at those locations.
How did you determine that you needed to modify the locations that you did? I'm not looking for each and everything you had to do, just a general overview of your process.
#98
I was thinking the same thing until I installed it. While I wish the resolution was higher, the swings are wide enough to see how mileage is affected by various factors. It's also high enough to show me that I seem to get the best mileage when going 75 MPH. A little touch of gas drops the MPG from 35-45 to 10-20 MPG, which is more dramatic than I expected. Likewise, it's interesting to me how much time it spends north of 30 MPG.
The next time I know I will be on a long uninterrupted trip I will reset the trip meters and see what I get.
And I am still recording my Trip data, I am almost at the end of this tank. The DTE for the Navi and MID have crossed again (the MID started out lower and now it is higher than the Navi) I'm not sure we're going to be able to establish a relationship between the 2
#99
Is there a part of the DIAG menu where you can tell how much gas the car thinkgs is remaining? This could help with my record of the trip meters. If there is, I will record this info also over the next gas tank.
#100
Originally Posted by mrodriques
IM me if you still need a place to host that file. I can set you up with an ftp link on my website if you still need it. No charge
To recap, BrandonClaps is hosting one
http://home.usadatanet.net/bclaps/MPG.rar
and I now also have another one running as backup...
http://www.savefile.com/files/56150
and remember, use Angrydad's original patch for v3.50 disc and use the above links ONLY if you have v3.40c disc. They're patched and ready to go.
Kenny
#101
Originally Posted by met152
angrydad,
P.S.: There is one bug that slipped through. Arrows in top-right corner of the info menu don't work as they should.
#103
I have updated my trip computer code so it refreshes the screen faster. It helps. It also seems to be possible to change the resolution from 5 mph to 1 mph with medium coding efforts, but want to complete nag screen removal first.
/AngryDad
#105
Not that I even noticed or really care, but will you be fixing that bug?
/AngryDad
#106
/AngryDad
/AngryDad
#107
#108
/AngryDad
/AngryDad
#109
I think so. If you go through the DIAG menu all the way to the Trip Computer info, there are a couple of lines in the list of values showing remaining fuel (in liters, I think) and the number it's using to determine remaining fuel, or something like that. The first number moves all over the place, probably due to the sloshing of the fuel in the tank.
#110
remind me how to get there again?
I'm trying to remember exactly, but it's something like DIAG>Functional Setup>Trip Computer
Basically, it's a long list of numbers that update about once per second and it shows things like speed in mm/sec, FUP (fuel usage) in mL/s, fuel remaining in liters, etc.
#116
Crap, I was hoping to be able to use that screen to check exact fuel consumption.
Angrydad, I guess this is another slight side effect of your patch.
There are two ways to get to TC in diag mode:
1. Patch diag.exe to enable this option
2. Use diag.exe from the bin where it is enabled.
/AngryDad
#117
This is unrelated to the patch. TC item in diag menu is disabled on the TL.
/AngryDad
/AngryDad
Also Bluenoise just confirmed and it is enabled on his but he had to do the whole edit and stuffing thing to get it to work on ver 3.3.
#118
/AngryDad
/AngryDad
Sweet. You are the man!
#119
Weird, I SWEAR i've been in there before or at least somewhere in diag that showed fuel consumption and current speed in like mm/sec or something like that. I have searched on AZ and can't find the info again.
I have the 3.30 version of the navi disc. My car is reading BN2HH12C.BIN. Someone here graciously sent me their patched 3.50 version of HMIManager.exe, but I don't know how they patched it (whether or not they used AngryDad's patch). I had to pack it back into my BIN using CEbin, since it was several hundred bytes too big to use hacknavi, even with some creative hex editing. CEbin is able to deal with it being larger by updating the offsets, apparently.
After I installed it, I noticed the disclaimer screen is totally blank (free of text) and the "OK" button now says, "Go." The person that sent it to me seems to have done the disclaimer screen tweaks, too.
When I access the DIAG screens with the three-button salute, I can bring up the Trip Information screen that Brian mentions above. I don't see anything that is grayed out.
