Eclipse 34230 amp
I'd rather be golfing
Eclipse 34230 amp
Does anyone have any experience with the Eclipse 34230 amp? I'm interested in using it to drive (2) svc 12's. I've read the specs and it looks good.
I see this amp is 2 ch x 370 at 4 ohm. the subs are 4 ohm svc 200rms/400peak. Figured I could just run ch1 on 1 sub, ch2 on 2nd and not stress the amp.
Dogmatic Dinosaur
That is too much amp for those subs. Get it and use it, but be careful - keep the gain low. I would not go over 200W on those daily. The amp will sound better and stay cooler running under capacity... and you have headroom in case you want to get different subs some day.
FYI - I am pretty sure that the amp does not bridge, so you are talking about running each sub on it's own channel - which is fine.
thanks, my thoughts exactly on the gains, and correct, it does not bridge.
oh, too late for that...bit my ass good. I've had those subs since mid 90s. They still sound great, but if I toast them I still got my moneys worth out of them.
so I'm going to pass on this Eclipse. Picked up an Alpine MRD-M605 from a family member. If anyone is interested in the Eclipse, I'll pass along the sellers info, just let me know.
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
