Easy way to quiet ratlle frmo center speaker/grille?
I have an anoying and now more prevelant rattle/buzz from my center speaker/grille. It used to happen just when the car was cold, but now rears it's head almost constantly and is very obvious whe idling and the car is cold. I can quiet it by pushing down on the center speaker grille consistently.
Does anyone know if the center grille is easily removed so I can try and silence this annoying buzz?
Thanks,
Stu E.
04 TL SSM/Ebony 6mt Venture/XPEL Clear Bra
Thanks,
Stu E.
WDP Director of R & D
Thanks,
Stu E.
Thanks,
Stu E.
Supposedly the grill just pops straight up -n- out. My noise is on the right side of the grill, yours?
I'll probably take the time this weekend to check it out...
Let me know what you find.
Smitty
Same thing here..
Smitty,
That's exactly where mine is (appears to be upper right). Do you know where these well placed paperclips should go?
Thanks for the insight,
Stu E.
Stu E.
Smitty,
Stu E.
Stu E.
The individual made it sound like it came out quite easily.... My rattle is very intermittent so I just haven't taken the time. Your recent post warranted a response due to mine reappearing just yesterday....
Maybe tomorrow I will perform "the surgery". All part of my WDP R & D.
Smitty
I had the same type of rattle coming from my rear right speaker (passenger side). I found that if you remove the carpeted covering in the trunk and look through the metal slots. You will see that the inside carpeted piece has plastic looking rivets. These rivets when the bass hits bounce against the metal causing the rattling. I placed a piece of rubber with two sided tape on to the metal, between the rivet and the metal. There are about 3 or 4 places. This stopped the rattling. I hope this will help someone else. It is so much nicer listening the the stereo without that rattle.
ITSJESTER
17
12-06-2018 02:29 AM
InFaMouSLink
10-27-2015 06:52 PM
