Easiest way to connect an aux jack
I've been reading thru endless posts about ways to add an mp3 player to the radio, but I can't seem to find the answer to my question exactly. First, I don't care one bit about the XM radio. I not signing up for it again. All I want to do is put an aux jack in the car for my non-Ipod mp3 player. What is the easiest way to do what I want? A detailed explanation would be extremely appreciated.
Thanks in advance for any help.
Registered User
if you searched then you would have found something
here is what i did
go behind the radio, remove the white plug from the radio (it's the XM harness) find out which 4 wires are the audio feed (i forgot which ones they are) 2 are positive and 2 are negative. cut them in half. wire a jack to the wires that are going in to the harness, and tape up the ones going back to the XM unit. plug the white harness back into the radio. now whenever you press the XM button you will hear whatever you have plugged into the jack
here is what i did
Use a cassette adapter. I use it for my Nano, sounds pretty good.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
