DVD-Audio Creation - The BEST Commercial Way to do it PERIOD!
#81
Originally Posted by datmrman
I think Ulead supports multiple groups, but I heard the TL wont play anything past group 1.
#82
The DVD-A Script Guy
mp3 support added to my scripts
For those of you that have been using my scripts...
I have released version 3 of the scripts. you can use mp3s directly now.
Get it at http://home.comcast.net/~adobeman/DVDA/
Version 3 Changes:
Let me know how it goes.
Version 3 Changes:
- Decoding of mp3 files to wav using BeSweet. Put your mp3 files in the same place you put your wav files and the program will decode them to wav. Default settings are to normalize the mp3s to 100%.
- Size checking (sort of). The program will try and check to make sure that you don't have to much material for one disk. The standard setting is MAXDVDSIZE=4650000000 in setenv.bat. Change as required for DVD DL.
#83
r00t
Version 3 Changes:
Version 3 Changes:
#84
Version 3 Changes:
Version 3 Changes:
Sample Output:
The files will now be made into a DVD-A structure and then an image
will be created. This will take a long time if you have a full DVDs
worth of songs.
Press any key to continue . . .
J:\DVDA>REM remove or change the "-ota( -g max )" seting for other normalizaiton
J:\DVDA>FOR %f IN (J:\DVDA\WAVs\CD_GRP1\*.mp3) DO J:\DVDA\CODE\BeSweet.exe -core
( -input "%f" -output "%f.wav" -2ch ) -ota( -g max )
J:\DVDA>J:\DVDA\CODE\BeSweet.exe -core( -input "J:\DVDA\WAVs\CD_GRP1\ASOT_217_10
-06-05.mp3" -output "J:\DVDA\WAVs\CD_GRP1\ASOT_217_10-06-05.mp3.wav" -2ch ) -ota
( -g max )
BeSweet v1.5b31 by DSPguru.
Using hip.dll v1.19 by Myers Carpenter <myers@users.sf.net>
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] | Input : J:\DVDA\WAVs\CD_GRP1\ASOT_217_10-06-05.mp3
[00:00:00:000] | Output: J:\DVDA\WAVs\CD_GRP1\ASOT_217_10-06-05.mp3.wav
[00:00:00:000] | Floating-Point Process: No
[00:00:00:000] | Source Sample-Rate: 44.1KHz
[00:00:00:000] +---------------------
[04:08:24:038] Conversion Completed !\
[04:08:24:038] Actual Avg. Bitrate : 132kbps
[00:01:27:000] <-- Transcoding Duration
Visit DSPguru's Homepage at :
http://DSPguru.doom9.net/
* SIZE WARNING *
* Current estimated size of all wavs is 3919283844
* Maximum allowed on disk 4650000000
* Change variable "MAXDVDSIZE" in Setenv.bat if you are using DVD DL
J:\DVDA>
#85
I may have screwed up something in the scripts with the max size check. The number reported doesn't seem too big but maybe it is and I didn't read it correctly.
There should be a file called wavsize.txt in the c:\dvda directory. Please copy the contents of the file into a reply (or PM me with it) and I will take a look. Wrap it in "CODE" tags please.
If you are a absolutely convinced that all your content is not too big then you can try editing the file setEnv.bat and changing the line "SET MAXDVDSIZE=4650000000" by adding another zero or two. You don't need to re-decode the mp3s unless you deleted the wav files. Hopefully that will get you though until I see the file you send me.
#86
Version 3 'available space' error
Adobeman,
I'm facing the same problem too. I changed the variable MAXDVDSIZE by adding 2 more 0's in setEnv.bat. Still no luck.
I'll send you the wavsize.txt document soon.
Thanks for all the help
P.S. It's my first post here... NEWBIEEEE! Just got my TL a week ago and I've been hooked onto this forum ever since.
- capri_tl
'06 5AT Black/Parchment + Navi
- capri_tl
#87
Here's my wavsize.txt
Code:
Volume in drive J is Backup Volume Serial Number is A031-42AC Directory of J:\DVDA\WAVs\CD_GRP1 02/09/2006 12:00 AM 1,319,938,604 ASOT_217_10-06-05.wav 02/09/2006 12:01 AM 1,303,985,708 ASOT_218_10-13-05.wav 02/09/2006 12:03 AM 1,295,359,532 ASOT_219_10-20-05.wav 3 File(s) 3,919,283,844 bytes Total Files Listed: 3 File(s) 3,919,283,844 bytes 0 Dir(s) 91,272,916,992 bytes free
#88
capri_tl / Irwin,
Looks like I messed up something. I'll go back to the drawing board for now.
Irwin, you content looks to be OK to fit on a single layer DVD. I'm guessing that capri_tl's is OK too.
Try changing line 66 of MakeDVDA.bat to add the REM that is in red below.
You will still see the message but when you hit a key to continue it should just go on and make your DVD rather than the quit it does now.
Sorry.
Code:
ECHO * Current estimated size of all wavs is %CUR1%
ECHO * Maximum allowed on disk %MAXDVDSIZE%
ECHO *
ECHO *
ECHO * Change variable "MAXDVDSIZE" in Setenv.bat if you are using DVD DL
ECHO *
ECHO ************************************************************************
pause
REM GOTO END
:MAKEIT
Sorry.
#89
Adobeman,
My file looks similar too. I'll try making the change you've specified above and see if it works.
However, in the meanwhile, I've been successful at creating 3 DVD-A's using Cirlinca. It's just that I'm having to first convert all my MP3s to WAV and then use Cirlinca. I shouldn't be whinning about it though.
Thanks again Adobeman.
#90
This may be a stupid question but I read through the thread and could not find an answer. When converting mp3 format to dvd-a does the sound quality increase? I am unsure if people are burning dvd-a for the increase in songs per disc or quality. Thanks
#92
With stereo (2 channel) music DVD-A is pretty much about getting more music on a a disk.
What actually happens is the mp3s need to be "decoded", or uncompressed, back into a format compatible with DVD-A. This is typically a wav or aiff file. So by using mp3s you don't get more songs on a DVD-A than if you had used wav files. This is because your mp3s will be uncompressed to the same size as wavs prior to actually getting made into the DVD-A.
So, if you have the CDs you should always rip to wav rather than use mp3 versions of the same songs.
CD ---(No loss in quality) -->WAV -->DVDA
CD ---(quality loss)---> mp3 --(possible quality loss)--> Wav ---> DVDA
I have added BeSweet decoding to my scripts since it seems to work on just about any mp3 I throw it. Even those with errors within. LAME is good at decoding too but had problems with many mp3s I fed it.
#94
No, the sound quality does not increase. It may actually decrease in quality a bit since there is a conversion in format and sampling rate. It is the typically sampling rate change that can decrease the quality. All depends on the decoder being used.
#95
r00t
Originally Posted by sriteja
It doesn't work properly on mine. After it says "... it is going to take a long time, press any key to continue" it quits.
#96
When I insert a music CD into my computer and browse to it, i see the songs as WAV files.Can't I just copy the WAV files directly of my music CD onto the hard drive without having to use Audiograbber to convert them?
#97
Scripts back up
My DVDA creation scripts are back up on my site.
There were some problems with the new scripts detecting total size but I think thanks to some help from Irwin Fletcher, I have worked out the bugs.
Also
It shows wavs when you put in a regular commercially made audio CD ? Usually you will need a ripper program for sure. Did you install any utilities that may be allowing you to rip via file explorer ?
Anyway, if you can copy them to the HD and they play fine with a wav file player then you are all set.
Also
#98
Will the TL show song and artist information on these home-made DVD-As? It doesn't song info for any of the commercial DVD-As i have such as Eagles, Crystal Method, or Santana.
#99
r00t
Adobeman... with the new version... the script is not generating an image if i use a temp drive other than the base drive. in the script, it says that it generaged the image at... E:/DVDA/Image/DVDA.iso... but that folder will remain empty. But... if i change the temp drive to the same as the base drive. It works fine.
#100
Burning DVD-A
---I am using Easy Media Creator 8 Suite by Roxio
---Memorex 16X DVD-R Media, 120 Minute(video)/4.7GB
"Disk Format" is flashing on the radio and eject it.
What is the problem?
I tried .wav or directly from cd..no luck
#101
When burning a DVD-A using the scripts, I've used DeepBurner Free to copy the ISO image and haven't encountered any problems. I have used Nero (older version) and made several coasters in the process. BTW, I'm still using the original scripts first posted by Adobeman - works all the time.
#102
Team Anthracite Member
Perfection!!
I've finally managed to create DVD-A discs flawlessly on every shot with no coasters. Either Cirlinca's program or Adobeman's program work great and it seems as though the type of discs I was using is the cause of certain songs ending prematurely. I was using Memorex DVD-R discs and when I would play them in the TL some songs would just randomly end early but when I played them in my home DVD player I had no problems. I switched to Sony DVD-R discs and have absolutely no problems after 7 new discs created. If I had to promote a brand of discs, right now it would be Sony DVD-R and the programs I would highly recommend are Adobeman's and Cirlinca's.
#103
I have searched the forums as well as google and cant find where to download Adobeman's DVD-A program for free that isn't a trial? anyone have direct link>?
#104
TL owner
does this allow CD text, that the biggest feature i miss going from my premier deh-800prs to the acura tl factory radio/nav screen, is no cd text only when im using xm.
saturno_v
10-28-2015 06:57 PM
rockyboy
09-21-2015 10:47 AM
