Does the Blackberry 7290 work with TL Bluetooth
I just got the new 7290, and want to know if it works with a TL. I will not get it tell next week, and hoping to buy a car this weekend.
Michael
Michael
You can only dial or call numbers stored in your cars phonebook. The other features are battery indicator and signal strength meter.
I use a Motorola HS810 headset and it works great. Very small and the battery lasts forever.
3rd Gear
Originally Posted by kmtoner
Do the Blackberry phones display any sort of caller id? If so, does it transfer to the TL's dashboard screen?
Any ideas why caller ID isn't passed from my BB? I tried a SE 637 and it worked fine.
Just upgraded to 7290, also. I have to hit a key on the 7290 everytime I start the car to agree to the blackberry link. I assume that I just need to change a setting. Anyone figure this out that can save me some r&d time?
Nevermind - I found an older post on the issue - https://acurazine.com/forums/showthread.php?t=99875
Originally Posted by Msnowdon
How do you like the screen on the 7290? It rocks from the 7210 that I had.
Michael
Michael
I just switched from the Motorola v600 to the Blackberry 7290. Both work well with the TL's HFL. With the bberry, I now get a battery strength indicator. One curious quirk, however. After much fiddling, I recorded sufficient PAUSES in my TL Phonebook to get my office voicemail without having to "send" further numbers. The bberry is a different story. I've tried many difference PAUSE sequences, and the Phonebook always clips the last two zero digits from my mailbox. I do not have this problem when I dial directly from the bberry. It only happens when using the HFL feature.
Blackberry 7290
Just got one myself. Replaced a Moto v505. The caller ID works, but shows a strange "_129" after the number (ie 3129046315_129). I can live with it, but it is strange.
Favorite feature is the transfer to headset feature. During a call, you can click the wheel and actually see "transfer to HFlink". I couldn't do this with the Moto.
Another issue, I use the security password (if I loose the phone, there is way to much personal data in there). You cannot make a call from HFlink if the Blackberry is locked. It tries to call and nothing happens.
I don't know if the 7290 model number is exclusive or not, but is that the Nextel version? Are you experiencing any "echo" problems? Mine works fine, with caller ID (& the ..129 issue), but my voice echos and so I don't even use it....
**nevermind - the 7520 is the Nextel version**
MilanoRedDashR
38
09-28-2019 09:13 AM
ivegotthenav
09-11-2015 07:51 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
SUPRMN84
09-02-2015 11:50 PM
