DIY Navigation Hack: The RESURRECTION thread 2015 on steroids!
Old 06-23-2016, 04:43 PM
  #81
hannamand's Avatar
^ Nope, they don't...
Old 06-24-2016, 10:18 AM
  #82
hannamand's Avatar
Finally got this to work last night, thoughts on the install:
- Pat isn't kidding when he says "Run quickly" in step 8... it will give you a disk error if you aren't moving your butt!
- Files don't have to be burned to a DVD, I used a plain old CDR and it worked just fine.
- Faststone viewer works great, remember to switch to 256 colors on the save as screen, and be nice, kick them a few bucks for the great free software.
- I now have the Cap'n America shield for my splash screen, but then it goes to a "Loading..." screen (I assume where the nag screen used to be)... it clears itself without hitting the "OK" button so I'm not complaining, but it would be nice if the splash screen stayed up until the map came up, I think it may be possible, DumpNavi.exe seems to have an option for it...
Thanks again Polish_Pat for putting this together and the YouTube video!
Old 06-24-2016, 10:19 AM
  #83
hannamand's Avatar
These should work now:
Old 06-24-2016, 11:58 AM
  #84
Hugo2go's Avatar
Can I pay someone to make one for my 08 TL-S?
LOL
Old 06-24-2016, 06:23 PM
  #85
hannamand's Avatar
LOL
No CD burner? Pat really lays it out step by step...
Old 08-01-2016, 11:34 PM
  #86
ezz358's Avatar
White disc
Could someone please post a link to instructions on doing what we can to the white disc
Old 08-25-2016, 04:24 PM
  #87
djspot's Avatar
No need to run...at least for me
Hey guys,
When I do this I don't run back and forth...I just pop out the original disc, insert the modded disc. Go back in the car, bring up the diagnostics menu, hit load with the modded disc inside. Wait for the system to do its thing. Once the mod takes affect, I get the error message about the disc, go back to the trunk put in the OEM nav disc. It automatically read the disc and Im good to go.
Since the original modded thread, I've probably done this upwards of 15-20 times. Never failed me.
Big up Pat for putting these files together.
Last edited by djspot; 08-25-2016 at 04:26 PM. Reason: Biggin' up Pat for putting this shit together!!!!
Old 12-31-2016, 02:40 AM
  #88
benderama's Avatar
Hello,
This is mostly a question for polish_pat.
Here's the situation: I have a 2005 Accord using the orange 3.50 disk and I was able to use the files you had to partially do the hack. I was able to change the background and removed the nag screen message but the button (which now just says "GO") is still there. I used the bin files you posted. Mine uses the BN2HN380.bin file specifically. At first I changed the background only and tried to load it up. The nag screen was still there, still had the ok button, no change to trip computer, no extra diagnostics menu from info screen. I tried it again also running the nag screen removal and it removed the nag screen message but kept the button which now says "go". Aside from the background and nag screen though, everything else was the same. So, no modified trip computer and no extra items on the info menu.
Here's the question: Are you sure you applied the nav hack to the BN2HN380 bin file?
Hopefully the answer is no. in which case there is a second question
Second question: What can I do get the properly hacked bin file?
Thank you and have a Happy New Year!
Old 12-31-2016, 02:49 AM
  #89
benderama's Avatar
Here's my background too
File Type: bmp
Old 01-07-2017, 06:37 PM
  #90
Liturgist's Avatar
Is there a Linux port for the SH-4
I would like to create a disk for the navi that is completely independent of the original disk. I have heard talk of a Linux port to the SH-4 processor. Did that happen?
I would like to build something based on OpenStreetMap that would be updatable and free. OpenStreetMap
Old 02-20-2017, 07:53 PM
  #91
Sam Hekman's Avatar
Older Navigation
I recently bought a 2003 Acura TL-S, and I'm loving it so I figured I better make an account, and I already have a question! Are there any hacks for the older Navis? My disc is version 2.60 and there's nothing on Google or the search on here. I just want to get rid of the stinking nag screen.
Old 02-21-2017, 12:54 PM
  #92
stevemk07's Avatar
Just a thought... Not hitting the ok button allows you to turn the screen off which I like... My old TL (07) didnt have nav and I kinda miss it like that lol
​​​​​If you delete the ok button you wont be able to turn the screen off I dont think.
Old 02-22-2017, 10:23 AM
  #93
sockr1's Avatar
Received 1,158 Likes on 909 Posts
you can turn the display off anytime if you go into settings, i did this all the time on long night drives.
Push the upper part of the "Settings" button (below screen, left of joystick), then select "Off" for the display.
Hitting any button thereafter will reactivate the display.
Old 02-23-2017, 12:00 PM
  #94
stevemk07's Avatar
Thanks!
Hack away.
Old 02-28-2017, 08:07 PM
  #95
We Are Venom
sbstnce's Avatar
Just want to say thanks! This was super easy, I skipped the splash screen as I had a v3.9 disc and couldn't figure out which bin file to edit. Guys! a quick tip, do not hit okay to open your gps screen. Just hold the buttons immediately and follow the instructions from there. If you load the gps it will immediately go back to splash screen. Hope this helps you. If you need, pay for shipping and I can burn a couple of these discs.
Old 03-02-2017, 10:30 AM
  #96
314_04TL's Avatar
You have a PM sir
Old 03-05-2017, 04:29 PM
  #97
8th Gear
fiveseven15's Avatar
Thumbs up
THANK YOU. i did this back in 07 or 08, upgraded the disc to the last version, and wasnt able to find the files again. thank you again for finding all of these and putting them in one place
Old 03-06-2017, 08:29 PM
  #98
n3o
n3o's Avatar
So can someone tell me whats the big benefit to doing this, because all I'm seeing is you can access the diag menu more directly rather than holding the 3 buttons?
Old 04-01-2017, 12:05 AM
  #99
specvmike's Avatar
Does anyone have the NaviHackAIO.zip file laying around? Looks like the Dropbox link in the OP is dead. Thanks!
Old 04-03-2017, 06:23 PM
  #100
Briam Bueno's Avatar
Dropbox link not working
anybody have the file ? the dropbox link is not working, will appreciated
Old 04-03-2017, 10:03 PM
  #101
peewizzle's Avatar
This hack allows custom splash screens if you want.
More importantly, it automatically skips the screen of text that comes up every time you start the car so you won't have to press the confirm/ok button anymore to skip that.
The most useful feature, in my opinion, is that there's a trip meter/mpg meter included as well. Instead of now going through the screens on the small LCD next to your speedometer to access that, you can now have a real-time mpg meter display on your nav screen while you are driving.
Another feature is that you can control your climate functions from the screen as well, instead of the physical buttons...although, I've never really had it work properly.
mrphilipanderson (06-14-2018)
Old 04-03-2017, 10:09 PM
  #102
peewizzle's Avatar
Here are the files located on my Google Drive, let me know if there are any problems downloading.
GOOGLE DRIVE LINK
full URL below if you don't trust the link above
https://drive.google.com/open?id=0B9...V9zbDBDV1BaRjQ
Old 04-07-2017, 08:50 PM
  #103
specvmike's Avatar
GOOGLE DRIVE LINK
Thanks very much!
Old 05-08-2017, 11:19 AM
  #104
3rd Gear
Drew Jackson's Avatar
Thumbs up Thank you
Thank you to OP and the original programmer(s) for this navigation mod. Attached is the image I used and an in car picture of the final mod in my 2005 Acura TL. Again, thank you to all who worked on this!
DIY Navigation Hack: The RESURRECTION thread 2015 on steroids!-img_20170508_113912-edit.jpg
DIY Navigation Hack: The RESURRECTION thread 2015 on steroids!-back.bmp
Old 06-02-2017, 12:45 AM
  #105
polish_pat's Avatar
Arrow
UPDATE JUNE 2017
Hey guys. I'm glad to see that after 2 years of posting this, the months of headaches spent getting to understand the process and know which file does what and where to find it, this still makes some people happy. I know i keep getting messages on youtube about a dead link to this thread and see that my dropbox link has also been broken so i'm updating both as I know this will still be needed for years to come.
NaviHackAIO.zip
The following 3 users liked this post by polish_pat:
Acura TL Builder (05-19-2019), Dingo (06-02-2017), JDoubleU (07-01-2017)
Old 06-02-2017, 01:04 AM
  #106
Dingo's Avatar
I recall doing this waay back in 2009 when I got my car ('06 TL w/NAV) and learned how to edit the splash screen to include a message from the car to me, and then my custom splash screen comes on - I forget which guys to thank so I'll thank you all for your support!!! I'll try and post a vid of it tomorrow if anyone is interested.
Old 07-01-2017, 10:01 PM
  #107
JDoubleU's Avatar
Edit by Administrator Ron A:
This thread/post has been edited since it was posted in the wrong forum, and also because you are not eligible to post a thread in the Black Market Forum yet.
All sale, trade, and want to buy threads or posts must be posted in the appropriate Black Market forum.
Members may not post new threads for sale, trade, or Want To Buy, in the Black Market until they have been registered for 15 days and have made 5 constructive posts, except for cars which is 60 days and 30 posts.
They can post in Black Market threads if they are responding about something being sold that they might want, but they may not post their Want To Buy request in other members threads.
If you are not eligible to post a thread in the Black Market Forum, you will just have to wait.
Please read THE BLACK MARKET RULES for more information.
I regret having to say this under these circumstances, but welcome to the forum.
UTAG @JDoubleU
Old 08-31-2017, 10:50 AM
  #108
mrphilipanderson's Avatar
What are the benefits ofhacking your navi?
I mean, what does it do? I see countless threads about how to and what you need to do it, but no one ever says Why someone would want to? What does hacking do????
Old 11-10-2017, 04:01 PM
  #109
3rd Gear
@mrphilipanderson
1. Allows you to skip the legal/safety warning message and button.
2. Allows you to put a custom splash screen image.
3. Access the diag menu directly.
Bpatton (06-07-2019)
Old 11-10-2017, 07:34 PM
  #110
keelo's Avatar
2008 rdx
hey guys I'm new here the name's keelo. I have an 08 rdx w/tech package and was wondering if this would work for me as i have a white dvd?
Old 11-11-2017, 06:20 AM
  #111
3rd Gear
@keelo
I thought it only works with the orange DVDs. But, you can try it - you won't hurt anything. And you can always put the standard DVD back in and reset it if it doesn't work. No problem.
Old 11-11-2017, 08:05 AM
  #112
keelo's Avatar
Originally Posted by Drew Jackson
@keelo
Thanks I'll give it a try
Old 11-21-2017, 11:46 AM
  #113
sushanthsuresh's Avatar
trip without OK button hack
Hi.
I have it working all perfect.
I am looking for the 401.bin file without the "OK " button hack and just the trip comp,diag menu, ac controls. Yes, I want the to press the ok button after the warning so the display is not always on.Any one have the original HMI.exe and diag.exe? Would it work if u just update the HMI......exe from the downloaded file to the original orange dvd bin?
Thanks in advance for the reply.
Old 11-22-2017, 09:22 AM
  #114
stevemk07's Avatar
Originally Posted by sushanthsuresh
Hi.
Fyi, you can turn off the display manually in settings.
Old 01-06-2018, 11:17 PM
  #115
T3CHSUPP0RT's Avatar
Just a quick question:
So no update on any mods for 07/08 besides the splash screen?
Old 05-07-2018, 02:44 PM
  #116
9th Gear
cristian102's Avatar
Anyone have a new working link to download these bin files? Much appreciated.
Old 05-09-2018, 08:02 AM
  #117
hrt
4th Gear
hrt's Avatar
I think this is all of the files you need.
https://www.dropbox.com/s/anhuq5x28u...0Hack.zip?dl=0
Old 06-14-2018, 03:52 AM
  #118
5th Gear
hl94's Avatar
The hack was successful in my 06 TL but does anyone know why changing the air mode on the climate control doesn't work through the navigation screen?
Old 10-05-2018, 09:01 AM
  #119
TongX's Avatar
Hey, can you update the links on this please? I have a "check your disk" issue and want to try if this would help
Old 05-04-2019, 10:54 AM
  #120
Yusuf Isa's Avatar
Modify the maps on the DVD
Hello Polish Pat,
This is a very nice hack you did, nice job.
My question: is it possible to modify the maps on the DVD?
I live in Nigeria and the stock Nav DVD is only for the USA.
I have a 2006 Honda Accord V6 A/T with Navigation.
Was hoping to utilize the built in Nav system if possible.
Thank you.
Originally Posted by polish_pat
UPDATE JUNE 2017
NaviHackAIO.zip
Quick Reply: DIY Navigation Hack: The RESURRECTION thread 2015 on steroids!
