DIY audio 'aux in'
#161
Take a diode from radio shack and hook it up like this to the relay coil,
positive ------ ()()()()()() ------ ground
I-----|<|-------I
The diode should not have any affect on sound per say, only when you turn it on and off. If you have other components hooked up to the +12V of the relay, it will cause feedback to it and cause the voltage to drop temporarily.
This was making my xenarc turn on and off everytime i flipped the switch from PC to XM sound.
I-----|<|-------I
#163
I would really like to hardwire my ipod into my 04 and want it as simple as possible...any thoughts? I want it be come threw the xm input as I dont use that and from all of the forums I have read that seems like the easiest way to do it. Is the 'blitzsafe' the way to go or the PIE X3 from logjam electronics? Any thoughts would be appreciated.
#164
^ Please see the 3G TL Audio & Electronics FAQ
#165
Also I'am in Canada, and it seem's there is a difference in the HU software... So the behavior is a bit weird. You have to double-click on the CD-DVD button to switch to CD-C Mode. But you have to cchange from one mode to another Mode,... Veeeeerrrry Sloooowwwly. Curiously when you start the car and the HU is off, the iPod still's play !!!
#166
Originally Posted by stefan2
I have tried all of the suggested parts and the only one that worked is the Blitzsafe. You have no control on the iPod with the HU control. But the quality is the best one.
Using the aux-in (xm input) is always still an option if everything else is not desirable. You can even set it up to charge and turn on and off with the car. However all the controls will be from the iPod itself.
#167
Originally Posted by chusteveb
Wow, that doesn't seem like a very good interface to me. I used the OEM iPod interface from Acura and sound quality is great, start up and shut down with vehicle is very prompt, and it always stays charged, plus track to track is very fast. Of course it is set up to run using the 6 premade playlist which wasn't a problem for me.
or you have to buy the Full HU for 1600$ :-)
thanx
#168
Do you know if the iPod interface for the TL is available separatly ? If yes is compatible with the 2005 TL ?
thanx
thanx
#171
my question was actually about what diode would be needed, but i figured it out.
the ipod adapter would do me no good since I need a 1/8" stereo plug, not an ipod plug. (unless it had both)
needless to say, I have already wired it up, and it was pretty easy. i am just waiting on my add-a-circuit to show up so I can make the relays live to test.
one more question: since on all four relays, you tie the power and grounds together, couldn't you just get away with one diode across the point where they come together? (or further up the line?)
#172
well, i finished it up last night, and it works great. i forgot to put in the diode when i was wiring in the relays, so when i turn off the aux-in while the car is on, i can occasionally see a blip on the nav screen. i will be going back into the trunk to install dom's backup cam unit in a week or so and will add the diodes back in then.
there is no volume loss that i can detect and the entire thing works great! thanks for the low cost solution!
#173
Instructions for 1G diy aux-in on a OE HU?
Hi,
Are there instructions for making a diy aux-in for my ipod on my 97 3.2 TL? Please send me a link if you have them. Thanks. I'd love to get my hands on those, provided that they are easy enough for a layman like me.
Fear and Loathing
Fear and Loathing
#174
Bumping this ancient thread I "found" (The link, like many their, doesn't work) in the 3G TL Audio & Electronics FAQ thread stickied at the top of this forum.
I've seen a few posts about cheap/easy AUX inputs for the older 3G's, here it is folks, the mother of cheap/easy.
*Disclaimer - The mod I'm about to explain REPLACES the XM Radio with an AUX input*
First, you need to get your hands on an RCA cable.
Then you need to follow this
until you get the following connection from the head unit exposed:
In the beginning of this thread they're tapping into the same connection, only they're doing it in the trunk where the harness leaves the XM unit and runs up to the head unit.
Use the following guide to wire up your RCA cord and test it out.
Attach the left positive channel of the RCA cord to 87 on the first relay (relay with the red XM wires).
Attach the left negative channel of the RCA cord to 87 on the second relay (relay with the green XM wires).
Attach the right positive channel of the RCA cord to 87 on the third relay (relay with the white XM wires).
Attach the right negative channel of the RCA cord to 87 on the fourth relay (relay with the black XM wires).
#176
I didn't see this mentioned here, so apologies if someone has already said this, but if you don't want to hack up the factory cable, you can buy a Honda Y splitter cable and hack that up. You can just search for that and find it. I got mine for $10 on ebay. I see the first comment over there is a guy who used it to do an aux-in on an '04 TL, so people have definitely found it for this use.
#177
I was thinking I could maybe tie the ground on the bluetooth device to SYS ACC, but I'm thinking it s just a signal that is pulled low when the ignition is on and tying it to the BT ground could damage something.
Thoughts?
navtool.com
31
11-16-2015 08:30 PM
