Which David Navone LOC to use?
2012 SH-AWD / Advanced
For the '07 TL-S, which David Navone LOC should I use to replace the OEM sub with an aftermarket amp/sub? It looks like the N85/V is the one to go with, but I wanted to get feedback from those who have made the same changes.
Thanks in advance.
Thanks in advance.
Retired!!! ON TOP!!!
Hey what's up...
When I did the addition of a sub and amp to my '06 TL, I used the NE-7V. Which is a two (2) channel LOC line driver. I then purchased a NE-774V to do the rest of the system, but, I decided to go with the Rockford Fosgate 3sixty.2. Both units are one of the best in the industry.
I still have the NE-774V in it's original packaging, so please PM me if you want to purchase it...
PS: Remember to disconnect the automatic noise cancellation system via unplugging one of the mic's under the front over head console area (where the homelink & dome lights are).
rodneyc77, I was wondering if you could provide a description of your 3Sixty.2 setup. I'm really having trouble getting good bass out of mine. It sounds muddy and hollow at best, and I've spent countless hours tweaking, to no avail. I'm really considering just taking it out and using an AudioControl LC6i instead. My current setup is taking the high-level signal post-stock-amp into the 3Sixty.2, then from there into two Alpine amps (M605 mono and F545 4-way). My speakers at ADS 346cs up front and Polk Momo MMC-650 in the rear, with an Infinity Kappa Perfect 10.1 sub in a 0.65 cu.ft sealed enclosure. Hope you can give me some good advice on this, cause it's driving me mad.
alan_rich
09-07-2015 11:08 PM
pmp93cl
09-23-2003 02:14 PM
