Could somebody be kind enough to help me out?
Ok, I did the following steps using Adobeman’s instructions.
1. I downloaded “Adobeman’s DVD GUI”
2. I clicked on “Make DVDA”……(it’s processing)…(Done)…”The DVDA image was created. It is at: “C\Program Files\Adobeman’s DVDA\IMAGES\untitled.iso”
3. This is where I have a hard time. I’m using Nero 6, but no luck
Could someone please walk me through the last step?
Thanks in advance.
BTW, sorry i had to make another thread. I thought i would get a faster response.
Thanks in advance.
Lt. Dangle
Thanks in advance.
Thanks in advance.
Here's a much simpler solution. Download Deepburner Free. The program is very intuitive, has a small footprint and will not conflict with any other programs. I haven't experienced any probs with it and BTW, I do have Nero and Roxio installed also. DB is much easier........
Thank you all for trying to help me.
Let me know if step 1-2 is correct cause step 3 is where I have trouble burning.
"Inside of nero.............File> open > choose ISO > burn"
Here goes,
I opened up Nero StartSmart and there are 2 options: DVD or CD.
I chose DVD
On the bottom there are 6 options: Favorites, Data, Audio, Photo/Video, Copy/Backup & Extras.
I chose Copy & Backup
Underneath Copy & Backup, there are 5 options: Copy Disc, Back up files, Restore Backups, Schedule Backups & Burn Image to Disc.
I chose Burn image to Disc
Nero asked to open the file…..Went to get the ISO file which was saved in the IMAGES FOLDER
Hit NEXT > Burn disc, but it did not save on the disc, it just made a Nero Disc Image instead?
When i get home tonight i will give the Deepburner Free a try.
Here goes,
I chose DVD
you have to use nero burning rom, not that. It is in the nero tab in the start menu. ALso what nero version are you running?
The DVD-A Script Guy
Tone-NBP - I PMed you before I saw this thread (in response to your message) and said the same thing as the others here.
You poor bastard . I'm a developer for a company with a help desk supports about 50,000 desktops around the world. I often comment that the help desk has an impossible job. They simply can't be expert on all apps. Especially custom business apps like I write.
Yes, "No Luck" is weak but this ain't no stinkin' help desk. Us IT folks should leave the surly, superior, RTFM stuff at work. But alas perhaps the inner monologue which must be restrained at work slips out under the cover of anonymity on a BBS
Originally Posted by noah82
As an IT Administrator running a help desk, a description such as "no luck" will not help us assist you with the problem.
Here goes,
I chose DVD
Here goes,
I chose DVD
Adobeman, thanks for the PM. I really appreciated. I did the same thing you told me.
I'm just going to try a few more and if that doesn't work, i will move on to the deepburning.
REC....I am using Nero 6.0 and i just tried the Nero Express
Asked: Which recorder would you like to use?
I chose E: HL-DT-ST DVD+RW GCA-4040N (DVD)
What would you like to burn?
I chose Disc image or saved project
Nero asked to open the ISO file, so i did that, click NEXT to proceed.
Now, it only take DVD+R and reject DVD-R disc.
So i used the DVD+R and it seems to work. When it was done burning, i tested in the car and the f'en thing didn't work?
Now, i read that the majority of the people uses DVD-R disc, but i must of selected something else cause it's not taking the DVD-R disc???
Your DVD writer probably does not support the DVD-R format.
Either replace the DVD writer (Internal or External) or use another computer that has a DVD writer that supports the DVD-R format. Or try other DVD+R media brands that may work on your TL. Try searching, others may have been successful with DVD+R.
OK guys, i got it to work but...
Here it goes.
I downloaded Deepburner, got it to work using Memorex DVD+R disc since that's the only option my DVD writer wants.
When done, i went out and test it, boom, it worked. I was extremely happy. Listened to a few songs, scran through all 39 songs.
After a while i test it again and it went DEAD on me
For some reason it would not work.
Could it be my Memorex DVD+R disc?
Here it goes.
Tone, fact is the ELS system prefers DVD-R instead of +R although a few folks have had success with them in their cars. The majority I believe use -R discs without encountering any compatability problems. The suggestion of getting a new burner would indeed solve your problem. So, was DB easy or what?
I read about that, that’s why I ran out and bought some DVD–R disc. When trying to burn it thru Nero, the burner rejected it. At the time I was so lost, I thought it was me, but really the burner.
Now DB was a piece of cake and it worked w/DVD+R and I didn’t understand why Nero 6.0 didn’t do the same. I like to get a new burner, but the one that came with my Dell I8600 laptop work ok. If this works consistently, then I don’t have to get a new burner.
Anyway, I appreciate your help. Good looking out.
Adobeman, thanks for the sweet program. You’re da man! I will look forward on your other thread converting it to 4 channels.
Thanks everyone.
Eggs999bacon
09-24-2015 10:08 AM
