Converging '06 TL stereo with '07 for AUX, mp3 support
Got me a '06 TL last weekend, gotta say i love this car coming from my '97 Integra Ls/Vtec. Anyway, i want the AUX into ability and not looking to add the USA spec or anything like that. What i want to do is get the '07 TL stereo bottom half (since i have nav) ...
Question 1: Is the difference of the '06 and '07 TL with nav stereos bottom half where the AUX input comes into play?
Question 2: Ive read the '07's had the little AUX input where you hook up your 1/8" cable for ipod and such in the armrest console, correct?
Has anyone attempted to do this?
Chapter Leader
(Northeast Florida)
(Northeast Florida)
You would have to check the wiring pinouts VERY carefully. With the 07 and up TLs having mp3 support and Pro-Logic II, there could be some extra wires that you would have to check. If you've checked the wiring, and they're exactly the same, then go for it.
I have an 06 that was non navi that i converted to the 08 navi with the mp3 radio and aux input.. the radio connector and antenna connectors are different. u can get an adapter for the antenna. the wiring u have to do some depining of the original 06 radio connector and pin into the 07+ radio connector. You will also need the aux connector harness and will have to pin those wires into the 07+ radio connector. Be a good idea to get the 06 and 07 wiring schematics etc...
you know that the isimple has an additional aux input right? with left and right rcas which is better then just the one aux in? AND the ipod connection too.. You activate it WITH the radio controls..
Just seems cheaper and easier to go that route.. especially since you dont really care for the ipod control.. which is what SOME people have issues with..
Then again, if your going with the 07+ radio may as well just add the oem aux. I installed mine in the center console similar to factory but further to the right. then under the acc plug i drilled a hole to run my wires thru for my iphone etc. then used a rubber grommet to fill in the hole. You cant even see it once you open the arm rest. Either way let us know what you decide to go with.
Done some more foot work. But nothing notable as of yet, the lower half of the HU would have to be changed and the re-pinning of one connector would need to be done. And the XM subscription would have to be changed to the new number
Haven't had a whole lot of time to tackle this
-=2005 TL=-
1 Post
Well, replacing the bottom can't be too difficult (minus the cost) and transferring XM subscription should be fairly simple (my original radio became inop and replaced the unit, please transfer without any interruption.) Probably the most difficult would be the pin out?
member psheu tried it and it didn't work out that well. He redid the pins for the radio and then got a VERSION error on the navi screen. You have to remember that the radio is tied directly to the navigation system, so you would need to upgrade the whole nav system to the 4.xx system as well!
It's much easier to get a USASPEC or Isimple, it activates the CD-C mode on the radio which is basically an aux input.
I ended up with the USA sepc anyway and has worked out great
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
4drviper
09-23-2015 09:00 PM
