the cluster of the acura tl 07 fit in the acura tl 04 yes or no
help i want to buy the cluster of the acura tl 07 to change my cluster of my tl 04 help
if you searched, you would see that the MID placement and the wire harnesses/signals are different as well. It won't work as far as we know.
I've the 07 cluster in my 05 TL. I get allways the information about the TPMS and the comunication to the airbag module dosen't work.
I'm trying to change the airbag module to 07 and perhaps i'll install the TPMS System, but i don't find one.
Former Whyner
Ohhh nice can u put a pic of it with the information warning.
Former Whyner
^Thanks for the speedy pics. The Info light and the airbag light are not such a big deal to me but can you at least take off the CHECK TMPS SYSTEM off the MID?
Also I have a 6MT so im sure my search would be harder. Think I might stick with my reg cluster but thanks anyways
When i push the reset button so i only have the small "i". The rest of the cluster is still in funktion so i don't have any problems with the swap.
Perhaps you can deactivate the TPMS in your bordcomputer by your dealer, but i don't have an Acura dealer here in Germany, so i can't ask.
05 TL A-Spec
Bring this one back from the dead..... Was swapping them just plug and play??.... What if any modifications did you have to make?... thanks.
05 TL A-Spec
thanks. That's a good idea, I'll def be doing that. Do you have to clear the TPMS alert everytime you start the car?.... and does it also repeatedly keep popping up every 10min or so needing to be cleared again like the maintenance/oil change msg does?... cuz that annoys the shit out of me. Thanks again.
