Climate control
'07 NBP TL
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
So I turn on my a/c, then when I switch it to auto, the air circulation turns off. When I turn the air circulation on, a/c is no longer on auto. Is there anyway around it? LA air sucks so I'm hoping I can just have the a/c on auto while its using the air inside the cabin and not outside.
Also, can I somehow close the center vents? thanks.
btw, this is for an 07 tl if it helps.
it's me, Alan Rickman.
Center vents do not close; you would have to change the air output location to achieve that
I don't think there is a way to stop automatic from using air recirculation; when my climate is set to a low temp and I start driving the climate control uses recirc for a little while then switches itself off and uses fresh air..
adreano17
09-29-2015 08:48 AM
