Canadian 2004 TL iPod connection
The 2004 TL radio doesn't have the XM switch. I'm considering buying the peripheral ipod adapter to connect my ipod and see the text on the display. Do I need to swap the radio for a US one ? Do I also need to swap the display ?
Thank you !
Will
Thank you !
Will
Are you 100 % sure ? I just remember seeing somewhere (in a ipod adapter installation manual) that you MUST have the XM switch. If you can confirm that this work, I would really happy to keep my headunit. What kind of TL do you have ? Canadian ?
Thank you !
Will
Thank you !
Will
I agree with The Dougler. It should work just like all the other units: DICE, USA Spec, Blitzsafe.
If you want to see for yourself try searching with the keyword Canad* in the Audio & Electronics forum.
Mode button confirmed on Canadian TL
I just installed a Dice Ipod module in my Canadian 04 Tl non-navi. Works fine! Dice channel is fed on XM input, selected with the mode button on the steering wheel.
Go ahead and do it! You won't regret it.
Carl
Carl
i have the usa-spec and it works fine on the candadian model. Just plug it into the back of the stereo in the cd changer slot. When u want to use the ipod u just press CD twice (first time it will go to your cds, second time it will say CDC and will be your ipod.)
Originally Posted by The Dougler
My dice will be in the mail monday as soon as I get it I will re-confirm what c_potvin is saying. I have Canadian 05 Navi.
c_potvin, is there any relation to felix?
May be we share some "goalie" genetics... but I have only a small fraction of his talent...
Good luck installing your Dice. Did you get the Silver series? Mine is the old R3. It works perfectly with my wife's 2nd gen nano. With my 3rd gen nano, it doesn't pause when turning the ignition off. However it does pause when switching input and when powering off the audio unit. Looks like I'll have to rollback my firmware in order to solve this.
Keep us updated!
Cheers.
Carl
GWEEDOspeedo
01-15-2016 10:39 PM
TLguy42
09-26-2015 11:27 AM
4drviper
09-23-2015 09:00 PM
