Bypass factory amp help
Need help bypassing factory amp i want to keep my factory radio and i am upgrading all speakers through aftermarket amp(s)... I tryed taping into amp plugs by disconnecting them and i get no signal... No navi! 2005 acura tl... Please help
Hi Welcome
This has been covered before so your best bet is to go on google, type in your question, in this case "bypass factory amp" and then add "site:acurazine.com" at the end so it only limits to this site
you'll find the following results:
https://www.google.com/search?q=site...hrome&ie=UTF-8
The search functionality on the site is no bueno.. Google works better
Here's what I did.
I took the speaker wires that are connected to the Input of the amp from the radio and turned them into RCA connections. Then I purchased an Audiocontrol LC8i and connected those RCA's to its input.
Then from the line driver you connect the amplifiers to it.
This is the line driver
https://www.crutchfield.com/p_161LC8...c&awug=9006936
This item shows speaker wire inputs so you may not need to convert the wires to RCA connections.
