Boston Acoustics G108 Sub in stock location
Has anyone used one of these subs?
Literature says will work as infinite baffle, sealed and ported.
I would like the most trunk space possible.
Thanks,
Dave
2005 TL
Thanks,
Dave
2005 TL
Started the install
Since I haven't had a reply I started the install tonight.
The sub will not fit without cutting room for the magnet. I cut out space and then put wood blocks next to the stock speakers so I can eventually seal this sub in a .3 Cu ft enclosure.
Hooked up to the stock amp, it is not to bad, a little boomy. The stock sub was blown when I recieved the car, so I have never heard what the stock amp can do. The sub is set at 2 ohms.
Next an Alpine MRP-M500 500 watt rms mono amp and to seal up the enclosure.
mrkingstonvi
02-22-2016 01:53 PM
handsom-hustla
11-13-2015 05:04 PM
