Bluetooth audio A2DP through Acura Music Link - SOLVED!
Hi team,
Here is my contribution to the community.
This is a quick solution (spent couple of days max) for playing music through Bluetooth through the Acura Music Link iPod interface.
My goal was to have something working before I hit the road on Thanksgiving (today in fact).
First thing I did I took the car console apart and discovered that Acura Music Link adapter without any line-in or RCA inputs. Bummer.
Next thing I did I purchased a 30-pin iPod dock-compatible bluetooth adapter on Amazon. It did not work either. CDC mode just kept flashing "Disk 01" and that was it.
So I researched a bit and discovered Acura Music Link talks Apple Accessory Protocol. So I adjusted my plans:
- I wanted to emulate Apple's accessory (an iPod);
- and tell Acura 'I am playing my single 72-hours long song from a single playlist';
- and then actually play music through Bluetooth.
So in the end I faked an iPod by programming Arduino controller, hooked up my existing Bluetooth (5VDC power supply; 3.5mm line out) to play music from the phone.
The is a temp solution for Thanksgiving. As a final solution, I want to:
- package it without loose wires through 30-pin breakout board;
- create a dedicated PCB and burn atmel chip with an iPod emulation code instead of using full Arduino board;
- and possibly use A2DP bluetooth shield for Arduino instead of external BT adapter;
- figure out power consumption and possible switch to idle mode when car's key is out.
But at the moment, I just excited to feel the force (well, the Arduino) and glad you can solve problems almost from scratch with it.
