Blackberry Tour - 2006 Acura TL
I have a Blackberry Tour 9630 with Sprint and cannot sync with the Hands Free Link. I have tried "searching" instead of "listening". Nothing seems to work. Any suggestions?
Blackberry Tour
I just baught a Blackberry Tour I had no problem linking it to the car. It took me a few trys because in the middle of pairing it would stop. Do the search mode. It been the best phone to work with the car, lots of options.
I also have a BB Tour from Verizon and did not have a problem pairing it. However I have problems placing calls. when I place a call it will not use the car bluetooth I have to manually activate it on my handset. Receiving calls its not a problem
I have the same damn problem. I can only receive calls through the hfl. The weird thing is that it actually worked correctly for like two days and then it went back to the same crap. I wonder if any one can shed light on this problem.
Post #1... go easy on a TL noob, but..
My tour was doing the same thing..ie.. couldnt answer an incoming call. I did some experimenting with the bluetooth options once the car and phone are connected... if you go into HFL bluetooth options and turn off the encryption, i found that worked for me..just an idea, but thought i would share.
sockr1
10-01-2015 01:31 AM
