Blackberry (crackberry) 8830
#41
7th Gear
Originally Posted by Bombavern
I am wondering if any one had the answer to this question. I got a new 8830 this week and have the same problem. I can manually pair easily, but it does not hold the setting for an auto connection.
#42
I just got a BlackBerry 8830 World Edition from Verizon (work phone -- no choice of carrier). I cannot get it to pair up with my '04 HFL.
I follow the normal process -- after I enter my 4 digit code, the phone goes on and reports it is paired, but the HFL remains locked with "PAIR nnnn" displayed on the MID. It'll stay that way for a few hours if I don't reset it by pulling fuse 6.
I've tried it with the BB set to discoverable and not -- doesn't make a difference. Anyone have any advice?
#43
I have the 8830 and it paired on the first try. Everything's great except for one small thing:
My bt headsets would auto connect to phone when dialing a call, but when I dial a call from the phone, it would default to the phone first until I specify send the call to the HFL, minor inconvenience I guess...
Any ideas?
Any ideas?
#44
Hi Guys -
I beg to differ. I have the 8830 with Verizon and as soon as I got my 07 TL-S (a year ogo) I was able to sync *and* transfer components of my address book.
If I recall, you need to create a category in your BB (I sync to Outlook so this was painless) [I called my Acura], and put the names that were most important to have in the phonebook within this category (I have 900+ names). BTW a name can be in more than one category.
When I started the transfer a question pop'd up probably on the BBY asking which category should be transferred. I highlighted Acura and the transfer just took a few seconds.
About a month later I added and removed names to the Acura category and did the transfer again.
Works beautifully.
Works beautifully.
#45
Any ideas?
Any ideas?
#48
I just got an Acura MDX 2008 this week. After many failed attempts I was able to download my phonebook from my Blackberry 8830 world phone. I made a phone call with my blackberry phone to my home phone (was in front of my house at time)-any open call would probably work. Then push the phone button on wheel and say "transfer". Now you have a live connection between bb & car. Now push the button to import cellular phonebook on nav screen. This worked the first time I did it. I realized that when I was trying to transfer it using the transfer phonebook button on my bb, it was not connecting even though it was synced via bluetooth. Hopes this helps someone else.
mrdeeno
Technology
08-23-2006 08:31 PM
