Battery Help
Battery Help
Greetings,
About a year and a half ago I upgraded my stock batter with a Yellow top, not cheap.
Then, about 5-6 months later, the yellow top died (could not get jumped or anything), and I got it replaced for free at autozone.
Now last week, the now 1yr old yellow top died again, it took a jump and has started 3 times since, but Im wondering where the problem is.
I do have some audio gear, but not that much power, I have a MS8, a Zapco two channel, Zapco 4 channel and an eclipse class d sub amp.
Do you think Im pulling too much juice for my alt to hang with (does not seem possible to me), or do you think these batteries suck?
I have a 08tls with nav if that helps.
I don't think it's the audio gear; I have three amps and everything is fine. Check the threads about the HFL not shutting down and having a very large parasitic drain. Of course you should also have your alternator checked out.
Optimas suck! Between my and my father, we've been through 8 of them in about 4 years. They will be fine one day and fail the next. Sometimes in just a month. Sometimes they never work great. My old Optima, before the company changed ownership lasted for 7+ years. It never gave out and that was in the GN with very high underhood temps and lots of vibration and g-force. Anything built in the last 5 years or so sucks. My father's installations were in the trunk where conditions are nicer for a battery and they still suck.
If you want a good battery at a decent price, look at a Sears Diehard Platinum. They're a re-badged Odyssey. Better performance than the Optimas and 1000% higher reliability.
I know it doesn't matter now but one reason I decided on the JL HD series was I wanted a class D amp that would be nice to the electrical system. However, your amps are not the problem, the Optimas are. If I remember right, a class AB pulls the same power whether the volume is low or high, at least that's what I remember reading.
Coolest A-zine Member
This it? Still pretty expensive! Will this help with my system? Seems like I have A TON of stuff to purchase here soon. Pads/resurface rotors, oil change, new tires (Yoka Avid w4's SUCK!), gotta buy some detail stuff as college takes its toll on the car
http://www.sears.com/shc/s/p_10153_1...2&blockType=G2
CCAs don't make a difference. You're only turning over a little V6. Go with stock or a little above unless you live in the arctic. The lower CCA batteries are more reliable, less prone to failure especially in hot areas.
MetalGearTypeS
08-29-2016 08:28 PM
