Aux input for MP3 player
Old 08-17-2014 | 10:51 PM
ranger's Avatar
ranger
I have been using a Scotsch? transmitter to connect a MP3 player to the stock stereo in my '06 TL. It works but drives me crazy as local stations start to cause interference. I always seem to be looking for empty stations.
Is there a simple way to add an auxiliary jack to allow direct connection? My wife's 2011 Nissan 370Z has one and it works great. Of course it needs an USB charger to keep the MP3 player charged.
I am not an electronics wizard and the car is now 9 years old so I don't plan to make a big upgrade in stereo equipment.
Any ideas?
Thanks,
Ranger
Old 08-18-2014 | 02:26 AM
Jackass's Avatar
Simple and cheap? Use a cassette adapter.
Old 08-28-2014 | 02:27 AM
erh723's Avatar
USA Spec PA15 HON3
http://enfigcarstereo.com/USASPEC_PA15_HON3.html
There is a step by step tutorial for the install on their website. It was very easy to figure out and the sound quality from it is great. With the cassette adapter i had some fuzziness to the sound.
Old 08-28-2014 | 05:35 AM
erdoc48's Avatar
06 Anthracite TL
I have the USA Spec and love it- no problems with it at all. Grom makes one as well, or go the iSimple route. It's all plug and play intro the factory head unit.
Old 08-28-2014 | 10:37 AM
blownby's Avatar
grom unit here!
http://www.gromaudio.com/store/usb_a...interface.html
AUX input,
USB for phone or flash drive,
added Blue tooth as well incase!
Old 08-28-2014 | 05:27 PM
Adobeman's Avatar
The DVD-A Script Guy
Tough one. If you aren't inclined to do the install yourself and you don't plan to keep the car more than another couple of years then, as much as it pains me to say, the cassette adapter may be your option. It will do better than the FM transmitter but won't come close to a direct wired solution. I'd really recommend a direct wired. Doesn't hurt to get a quote from a local installer.
Also, the video of the TL installation at the link erh723 provided is exactly how I remember doing my install so I would recommend you watch it and see if you think you, or a friend you by pizza and beer, could do.
Old 12-21-2014 | 11:39 AM
TLCutter's Avatar
I just purchased a 2006 Acura TL for my son. I just purchased the USA Spec Hon3.. Will I need any other cables for his Apple I-Pod. ??
Old 12-21-2014 | 12:13 PM
erdoc48's Avatar
06 Anthracite TL
^^ If it's an iPod with the older style 30 pin connector, you should be good. The cable for the iPod will interface the iPod to the audio of the car (and I believe it comes with the USA Spec). There's also an AUX connection to which you can connect a BT device so if he has a cellphone, he can stream BT audio.
TLCutter (12-24-2014)
Old 12-21-2014 | 09:00 PM
bissettbd's Avatar
5th Gear
iSimple ISHD571 Gateway Automotive Audio Input Interface Kit for Select 2004-11 Honda
iSimple ISHD571 Gateway Automotive Audio Input Interface Kit for Select 2004-11 Honda and Acura
Works Well in 04 TL. Got it when my CD player crapped out.
Update Firmware before installing. Mine would not work without firmware update.
Amazon.com : iSimple ISHD571 Gateway Automotive Audio Input Interface Kit for Select 2004-11 Honda and Acura : Vehicle Audio Auxiliary Adapters : Car Electronics Amazon.com : iSimple ISHD571 Gateway Automotive Audio Input Interface Kit for Select 2004-11 Honda and Acura : Vehicle Audio Auxiliary Adapters : Car Electronics
navtool.com
3G MDX (2014-2020)
32
01-20-2016 12:43 PM
navtool.com
31
11-16-2015 09:30 PM
thegipper
09-28-2015 02:01 PM
navtool.com
09-25-2015 06:15 PM
Quick Reply: Aux input for MP3 player
