Attention Motorola Q Users...Upgrade your Phone Software!!!
For those of you that have a Motrola Q, you probably have been frustrated with the compatibility of the HFL. During an incoming call, it would drop for a second and then pick it up a few seconds later. The signal strength did not display in the MID.
I just installed the upgrade from Motorola, and all of those issues are gone! Keep in mind, that you are essentially doing a complete reset of your device, so you will need to back everything up and then restore it after the update, but I am very pleased with the performance of the device and the compatibility with the HFL
Here is the link to download the update:
http://direct.motorola.com/hellomoto/support/update/
Just select Verizon as your carrier, and the Q as your phone, and it will give you the link to download the update.
I did the upgrade and still get the weird drop, pickup behavior on the first call. The signal and battery strength both read now.
Also be warned the upgrade can have undocumented side effects. I had to take my phone to Verizon because, SOMEHOW, my phone went totally nuts and lost all of its identity/NAM select settings after it successfully upgraded. All it would do is roam the Alltel network so I couldn't *228 or *22800 it to program its info. The guys at the store were like "WOW, we've never seen a Q do that!" Thirty minutes later, they had it reprogrammed and all was well.
jz
I also did the update and the Q is much more compatible with HFL.
I ran into trouble with getting my exchange server to work again after the update. If anyone has trouble with getting their root certificate installed I can give a step by step.
JZ
JZ
Verizon - Q upgrade results
I applied the Moto software update yesterday.
After the pain of having to reinstall all apps, etc. I can report only minimal improvement in my TL.
I now have both battery and signal strength displayed but still have the weird issue where you can place a call via HFL, then have it appear to drop, hit button and say "transfer" then it's OK. Acura is a 2005 TL.
For those of you on Verizon, has anyone seen this behavior disppear after the upgrade so the phone works like it should? If so, do you have any tricks (multiple attempts to find/pair, etc.) to offer the rest of us?
I have a 2006 TL and really like the motorola Q, but if its not going to work well with the TL i might just go with the chocolate.
Has anyone had NO problems setting up the HFL with the motorola Q?
The Q works perfectly once you upgrade your software...if you are buying a new one chances are that it will already have the software update installed on it when you receive it.
For a smartphone, it is pretty reasonably priced. If you qualify for the new every 2 program, you can get one for $199. If not, it shouldn't be too much more to grab one on ebay.
Still seeing some issues (Moto Q and 2005 TL)
I agree the Q is a good phone and have recommended it to others. I've even had good luck/performance from my Q after applying the software upgrade.
BUT ... I am still having problems pairing my Q with my 2005 TL. I've paired and re-paired it, a total of three different times. The car paired easily - and reliably - with an earlier Motorola phone (v710) but still has quirks with the Q. I'm attributing this to the Q's HFL Bluetooth implementation still being a bit flakey.
I'd love to hear tips on successful pairing the Q with HFL in the TL from those who've had really good results. Based on my experiences, I'll just close with that familiar warning ... note: your mileage may vary.
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
For some reason, in my 05 TL, I cannot get my Q to link up correctly. When linking the HFL and the Q, it says it recognizes each other, but then once I go to place a call as a test, it says that no phone have been synced with the HFL system. Any advice?
One tip ...
Once you place your call from the steering wheel's HF buttons, and the Q/TL has apparently decided to drop it for you, hit the top button again and give the command "Transfer." For me, that seems to pull it back from the Q to the TL and allows me to complete the call hands-free. Subsequent calls (in close proximity to that first one) sometimes go through without needing to transfer back from the Q to the TL. It's not perfect, but it does work for me. Hope it will for you, as well.
This is a know issue with the Motorola Q. Interestingly the Q and the RL, or any other Acura, worked perfectly before Moto "upgraded" (Degraded) their firmware from version 1. As a matter of fact I am sending my Q back to Motorola to have them put back that firmware version. We can't do that because user installed firmware can only be *upgraded* we can't go down a version.
Motorola is working on a fix but don't hold your breath.
KAPS
KAPS
KAPS
KAPS
For what it's worth, I have an 06 TL with Navi, a one month old Black Q from Verizon, and it links up perfectly, with full functionality including battery and signal displays.
One note: even though the car manual and the voice guided instructions imply that you have to put the phone in discovery mode and then the car will find it, it's really the other way around. You add the car to the phone's hands-free device list just like how you'd add a bluetooth headset. Navigate on your phone to the Bluetooth Manager, then instruct your car to start searching for a phone, then hit Connect on the phone and you should find it.
Ryan Christopher
I just got the Q last week. The phone syncs up fine with the car, displays all information, but it is not as loud as my Motorola V710 was. I really have to turn the volume up to hear someone. Is there a way to increase the output volume from the Q? I tried to see if it was tied to the headset output, but it is maxed out and does not help.
Thank you, Jason
Thank you, Jason
I am having the same issue as others with the Q. When placing a call from my 06TL the phone dials then disconnects from the car. If I say transfer it comes back. I upgraded the phone to the newest version form Motorola and the problem still exists. The phone is on Verizon and is only 3 days old. Any advice?? I had a Blackberry as my last phone and it worked great with the TL.
Back in the saddle..again
Here's a weird one. Got my moto Q to pair perfectly (Sprint got it 2 weeks ago). No need to hit the transfer button. I was having problems getting active sync to work with my email. Finally got that to work with active sync 4.5. I had to re-pair my phone with hf link because I had to do a master reset on the Q. Now I have to say transfer as the hf link drops the connection when dialing the number. Will the update for verizon work with the sprint phones and what version is the latest for the Q?
I had this same problem with the Q and contacted HFL about it.
The customer service rep knew of the problem and said it was due to a setting in Active Sync. I changed it per his instructions and it has worked perfectly ever since.
Here is what to do:
1. Go to Active Sync.
2. Select Menu, then select schedule.
3. Change the Sync time to anything other than "As Items Arrive".
This does eliminate immediate push email but I set mine to 5 minutes and it is fine for my use.
Here is what to do:
Here is what to do:
Here is what to do:
I have a question specifically around your comment regarding not having to say Transfer. I presently have a Q and I'm also on Sprint and when I initiate a call from my phone I have to say transfer in order for my call to come over the HFL. Any help would be appreciated if you know a way that I can get the call to transfer automatically.
well it gets even stranger. First it worked properly then it started to drop the calls and I had to say transfer and now sometimes I have to say transfer ther times it works fine. I am doing some testing and will let you know what I find.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
