Anyone use an LG 8700 with their Acura?
I can't seem to get this phone to work
I set bluetooth on, and make it visible and it doesn't catch it
What can I try
What can I try
I have one and it worked fine at first. Got in a scuffle one night and the phone ended up hitting the ground pretty hard. It works once in a while now. I figured it was just from the phone hitting the ground.
AZ Community Team
Received 7,771 Likes
Try using "0000" as the passcode and use the "auto pair" feature if the phone has one.
ok, I got it to work doing it the regular way.
The trick is the timing. You have to tell the phone to "add new device" just at the right time. I did it just a couple seconds after the car starts its search. If you do it a little before or a little after it doesn't catch it.
Worked ...did a test call too.
Zonian22
11-14-2015 01:20 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
sockr1
10-01-2015 01:31 AM
asahrts
09-04-2015 05:55 PM
