Anyone getting this weird Navi message?
I did a search for this and found a reference to it a while back but didn't see any solutions or advice posted, anyway sometimes when I've mapped out a route with the navi and ignore the directions on the screen, instead of recalculating a new route all of a sudden I get the following error in block letters: "NO ALTERNATE ROUTE FOUND, ORIGINAL ROUTE WILL BE GUIDED" or something to that effect, at which point the route disappears, along with all route guidance (voice, direction list), just as if I had gone to "menu" and manually cancelled the route
What's really weird is that it happens in areas that are fully mapped (today was in downtown Miami), and when I input the same destination again immediately after the error the navi finds the destination and maps out a route as if the error had never happened
Anyone have this or know what causes it?
05 C230K & 09 135i 6MT
I thought that error meant that you drove off course and it recalculated the trip, but if it couldn't find an alternate route, it just wanted you to stay the original course.
Seen it the first day I got my car because I took another route because I didn't like the route it gave me. When that the message popped up, and the routing ended, I was like WTF?
In all honesty if you know a better route to your destination than the navigation was providing, why use it?
It's not really intended to guide you around a place you already know, it's for places you are unfamiliar with. If you use it to guide you around places you already know, you're likely to find conflict with it every single time. But if you use it to get out of unfamiliar areas, it's a life-saver.
That, or it just has a bad attitude.
Simple, I didn't know a better route, on this occasion I was using it to go to a destination 100 miles away that I had never been to before and the error message came when I ignored the navi's instructions on which entrance to take to the highway, it told me to go straight but I knew that there was an easier way to get to the highway by making a right turn
Team Anthracite Member
I got that message for the first time about a week ago (after about 6 months ownership). I was going to a destination in a well mapped area as well (Weehawken NJ right accross from Manhattan - literally on the Hudson River) and decided I didn't like the route shown and usually the Navi would just recalculate after I didn't follow it's directions. But no, it gave up despite I obviously was still on a known (the Navi knew what road it was before it stopped) road in-as-much as about a quarter of a mile forward I restarted the Navi to the same destination in Manhattan and it knew where I should go. WTF? If I had been in an area that I didn't know I'd have been pissed.
Dumont
Dumont
Dumont
Dumont
Keep Right Except to Pass
I've had that happen to me once or twice. The solution is just to say "Menu," then choose how you want it to calculate your route. It will still be trying to send you to the same destination, but it won't do anything until you tell it to resume.
The times it's happened to me have been (1) when I take a new ramp from the Beltway to I-95 south (it doesn't know the ramp is there and gets confused because it thinks I'm off-roading) and (2) when I'm driving in the reversible HOV lanes on I-95. The Navi will NOT route you into the HOV lanes, I suppose because they're reversible and because the Navi designers don't want to listen to complaints from people who blindly follow the Navi in there despite not having three people. So anyway, if you drive in there, it gets confused at one particular spot near Woodbridge where the HOV lanes are some distance away from the local lanes, and it displays the message described in the original post. You have to wait until you're about two miles south, then say "Menu" and choose a route preference.
Were any of y'all on roads that are sometimes subject to various restrictions when the Navi hiccuped at you? It would be interesting to know whether that's the cause. We have some streets around here that completely reverse direction at certain times of day, but I've never thought to see whether the Navi would get befuddled by that.
Originally Posted by A_UFO
What version is your navi DVD?
Hmm now I'm even more confused about the errors I'm getting, at least in your situation it makes sense because of the HOV lane or what not but the first time it happened to me was in my parent's neighborhood in Orlando which is a completely residential area so no highways, etc., the navi took me from Miami to the Orlando house with no glitches but then when I left after a couple days to go back to Miami I mapped a route to my house and after about 30 secs while still in the residential neighborhood I got the error
the second time was in downtown Miami, it wanted me to keep going straight for an entrance ramp to I-95 and got confused when I ignored its suggestion and made a right turn instead, immediately I got the error
because it happens so infrequently I'm not too worried about it, more curious than anything as to what can cause it, I still think my hunch that it has something to do with a momentary loss of access to the satellites fits because it would explain why it happens in areas that are fully mapped and even then only sometimes, for instance with the I-95 error I wanted to see if I could reproduce the error and so I mapped the same destination and did the same thing (turned right instead of heading straight) and it worked fine
Anthracite Trend Setter
Don't feel like reading all the responses, but I have gotten it several times on my 04 TL. Simple fix is to just hit menu and press the same route again. For example I always use direct route, so I press that button again and it will put put the route back on the screen. Not a big deal, simple fix. Does seem odd when all of a sudden you lose your directions and route from the nav though.
Good question, I have been too lazy to check but I got a 2005 TL in late October so I guess I have whatever version was the one before the latest update was released
The latest version that was release at the end of October 2005 is 3.50
The latest version until recently was 3.40c
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
