anti theft light
Old 01-20-2018 | 07:23 AM
steffeac's Avatar
9th Gear
anti theft light
2005 Acura TL, 195k miles
Anti-theft red light keeps blinking sporatically while driving. Sometimes it will blink every 2 seconds, other times it will stay lit for minutes at a time.
Anyone know what this means.
FYI....ECU was just replaced about 4-5 months ago. Old ECU apparently shorted due to a blocked AC drain tube causing moisture to ruin it, which in turn caused the #1 ignition coil to fire way over voltage, which in turn caused ignition coil to fuse/burn into the ignition sleeve above the spark plug. Sounds like poor engineering design if you as me....
Old 01-29-2018 | 12:13 PM
LoveMyTL-S's Avatar
Anyone?
gwai1o
01-05-2018 04:08 PM
Dantes
06-10-2004 01:03 PM
BarryH
07-01-2001 05:56 AM
Quick Reply: anti theft light
