Amplifer Wiring question
Old Jun 2, 2010 | 02:12 AM
mwang408's Avatar
Quick question to do with wiring an amplifer with an LOC.
What do I wire the remote wire to? normally on an aftermarket HU I would know what to wire it to. But what about on this car?
Old Jun 3, 2010 | 12:50 PM
mwang408's Avatar
bump i need the answerrr!
Old Jun 3, 2010 | 12:57 PM
jsilas's Avatar
THƎSƎ HOPƎFUL MACHINƎS
When I installed an amp in my CL, I just stole power from the factory amplifier power circuit. Whenever the head unit was powered on, the factory amp powered on, so I located that wire, put a splice onto it, and connected it to the aftermarket remote lead input.
Worked like a charm....
Old Jun 3, 2010 | 11:52 PM
mwang408's Avatar
awesome thank you! oh, and when u say u stole power from do you mean you didnt have to run a seperate wire to the batery?
Old Jun 4, 2010 | 12:10 AM
jsilas's Avatar
No no - I still had to run the main power cable from the battery. I'm just saying I tapped into a remote-turn-on wire in the factory harness with which to power on/off my aftermarket amplifier.
Old Jun 7, 2010 | 10:09 PM
mwang408's Avatar
Anyone know exactly where i can find the remote turn on wire in the 3rd gen ? and what color it is
Old Jun 7, 2010 | 10:29 PM
tragichero's Avatar
My Other Ride is a Huey
I went with the "add a circuit" route and just plugged it into an open spot on the interior fuse box under the driver side. Ran that to my amplifier as my remote.
Old Jun 7, 2010 | 11:57 PM
mwang408's Avatar
awesome i got the remote turn on. however when i got to the part of putting in my LOC i have no idea how to do it. it is a stinger 2 channel loc. btw i am using this for my mono amplifier. anyone have the wiring diagram? or can tell me how to do it?
Old Jun 8, 2010 | 11:19 PM
jsilas's Avatar
Easiest way is to splice into the two rear speakers' wires and connect your LOC to them. Then run a pair of interconnects from the LOC to your amplifier inputs, adjust your gains, and you're good to go.
BoricuaTL
Apr 8, 2016 01:08 PM
Type S Zero
Feb 17, 2016 02:37 PM
VA2000TL
Oct 2, 2015 08:26 AM
datadr
Sep 12, 2015 09:12 PM
alan_rich
Sep 7, 2015 11:08 PM
