Amp wiring question
All Around Klown
Amp wiring question
OK... need opinions... I cant handle not having my thump anymore... I want to get my Infinity Basslink Sub wired up in the TL and want to know:
First: where you guys run the feed wire for the amp power... up the middle of the car (under the console and such) or down the door sills/railings...
Second: can I tap into the on/off signal wire for the factory amp to turn my Infinity sub on and off?
Third: My sub has audio jack inputs as well as direct feed input. can I disconnect the factory sub and rout those directly into the Infinity sub feed. I've never ran pre-powered wires into an amp before.
Dogmatic Dinosaur
The stock HU is on all the time. It is necessary for HFL and Navi (if applicable). Most of us use and accessory fuse (like #32) to power the audio equipment.
I ran my wire down the drivers side. Around the foot rest can be tricky if your wire is thick - I have to modify the trim to fit over 0 gauge.
You can use the signal from the sub in the trunk. The gold/black wire is the positive.
BoricuaTL
04-08-2016 01:08 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
alan_rich
09-07-2015 11:08 PM
