aftermarket Radio in place of factory display?
Can you place a after market double din radio in place of the factory display(not were the factory radio is) The display i am talking about is were it shows u climate control and radio display. I want to know if u can move the factory display to were the factory radio is and then replace it with an aftermarket double din were the factory display use to be at. It will look better then replacing just the factory radio and looking down just to see the screen?
get a touchscreen by itself (usb connects to a pc to control it)
you can do a captuter setup that way
youre pretty limited on options otherwise it will be a display mostly.
try looking for a radio where there is a separate display and separate control unit i know they used to make them a while back
handsom-hustla
11-13-2015 05:04 PM
09-15-2015 06:44 PM
trinikidcl
09-04-2015 12:56 AM
