After market alarm mimic OEM? (roll down windows)
Does anyones aftermarket alarm/keyless entry, mimic the OEM one so if you hold the unlock button it will roll down all the windows.....WITHOUT an extra module like 529/530t
Originally Posted by streese
No. The aftermarket alarm does not send a second signal once the first signal is sent to unlock. You MUST use another module.
Steve
Steve
Originally Posted by BrandonClaps
i could have sworn someones did unless they did use a module...
If you're going to put in an aftermarket alarm, do the remote start, and leave your air conditioning on all the time.
Steve
It CAN be done, but you have to go into the doors to do it. Painful process from what I understand. And it only gives you down, just like factory.
Steve
Steve
Originally Posted by r8ul
Did you have a problem with the alarm not unlocking the doors when it was remote started?
I have those wires hooked up in the door. when it is remote started I have to hit unlock three times to unlock the doors, and it works normal at all other times
window roll up down dowontec st-800 pulse
How close together do the pulses have to be? I'm using a Dowontec ST-800 Push button start alarm with 2 aux outputs that I can setup to do either a pulse, or 1-7 seconds constant output, but in order to activate those auxillaries, you must hold a button down on the remote for 2 seconds, so I don't know if i could get the "pulse" and "Pulse-hold" close enough together?? What do you think?
TLDude876
12-28-2016 03:18 PM
BoricuaTL
04-08-2016 01:08 PM
dlknight
09-02-2015 10:42 AM
