Add an AMP
HASTA LA VICTORIA'
Add an AMP
Just doing some research before I go ahead and take apart my car for this.. Can I just use this ->PAC AOEM HON20 ADD RADIO AMPLIFIER AMP INTEGRATION INTERFACE HONDA ACURA
http://www.ebay.com/itm/271024006404...#ht_2029wt_838
with this ROCKFORD FOSGATE PBR300X4..??? Soundnoob over here.. Some advice will help!
could be used, but absolutely not needed if the amp is chosen correctly. plenty of build threads for you to research on here.
cipdagr3at (12-30-2012)
I think itd be more useful to have a female connector of both the inputs and outputs on the amp, to just loose wires.
I want to add an amp, but not cut any of the factory wires. I essentially want to unplug the factory input to the amp, and plug it in to a connector that just has bare leads on it and run those to the amp.
Go for it
HASTA LA VICTORIA'
Here is the unknown for me on that cable. I am not sure that I can select to have say the rear and center channels remain and pass thru to the OEM amp. I only need the front left and right full signals to go to the aftermarket equipment.
soupi
14
11-15-2015 11:15 AM
InFaMouSLink
10-30-2015 09:43 AM
